LeeElms
I have a strange problem, I'll try and be as clear as possible:
When playing back a recorded DVD, the picture is fine, but the TV is receiving both the sound from the recording being played and the sound from the channel the DVD recorders tuner is currently tuned to.
TV: Samsung LE40D580
DVD recorder: Panasonic DMREZ27
Both the TV and the DVD recorder are fed from a normal rooftop aerial for the Freeview signal. The DVD recorder is connected to the TV using a SCART cable. It doesn't make any difference to this problem if the SCART is swapped out to an HDMI cable. If the aerial connection from the DVD recorder is disconnected, the problem is resolved .... but this isn't really a solution, as disconnecting the aerial cable between recording and playback isn't exactly convenient. The best workaround I know of is to tune the DVD recorder to a channel that doesn't have sound currently, but this has to be done repeatedly as the channel is changed when a recording is made.
I can't spot any settings for either device that seem to relate to this problem. I've tried 'googling', but don't get anything useful.
Any ideas ?
Any ideas ?
