Prevent Workshop floor rotting?
dsc
New member
14 Dec 2015
dorset
Hi
I have a shed/workshop that I want to reinforce the exiisting floor. I intend laying on top of the existing floor (T&G 11mm shiplap) some 18mm moisture resistant chipboard. I may also insulate with some polystyrene.
Question is, is there a chance that damp will accumulate between the two floors, and if so is there any way to help prevent this?
Dan
Hi,
there are two basic techniques for stopping moisture getting trapped where it could cause damage:
1) Vapour barriers - e.g. a plastic sheet to stop warm air finding its way into a cooler part of the structure and depositing moisture as condensation.
2) Ventilation - keeping areas where cold air is unavoidable, well ventilated to outside air so that any excess moisture condensing there can be carried away. You obviously need to provide ventilation in a way that doesn't provide a home for vermin (DAHIKT!).
You can use one or both techniques in a given situation. More here and elsewhere: https://en.wikipedia.org/wiki/Interstitial_condensation
Cheers, W2S
PS I forgot to add that as a defensive measure, it would be worth using only preservative-treated materials.
Thanks for this. So for the floor it should it suffice to just lay a vapour barrier between the existing floor and new chipboard floor? I was originally worried that any rising damp from the bearers and existing floor would be trapped between the two floors and rot the original floor (which would I guess be affected more so than the new chipboard floor).
Dan
