Pre-Drilled Flat Bar
SteveF
16 Sep 2013
Maidstone
I am trying to find some short lengths of flat bar about 150mm long x 15mm x 15mm with 6mm holes
is this available? or do I need to get it made ?
it is for a dowel jig...that will probably never get used again
I have looked at all the expensive and cheap jigs and none really do what I want
the joint genie gets close but references from an end
rockler made what I want but only in imperial
Steve
Steve
How about this?
http://www.diy.com/nav/build/building-m ... Id=9283036
Hi
If you have a pillar drill then just make it yourself, I'm not aware of anywhere you could buy it off the shelf.
6mm is no problem with a sharp good quality drill - no need to pilot but use cutting compound - I use Trefolex, clamp the work direct with an MDF packer to save marking the table.
Regards Mick
And eBay is as good as anywhere for small amounts of stuff.
Spindle":2qnyu7zy said:
Hi
Regards Mick
I thought about trying to do it myself
I even looked at the spare guides you can get from axi..i could then switch them for different sizes
not sure what size threads they are though
am i allowed to post links ?
http://www.axminster.co.uk/replacement- ... elling-jig
Steve
Few more ideas...
If it is a one off why not use hardwood? And for bushings, a copper plumbing fitting or even a bit of pipe. 6mm sounds like a gas fire pipe size maybe.
Jig bushings would be better, but it really depends if it is a use once in a while jig or not.
Hi
If you use the guides you linked why would you want to use steel for the body? Just use hardwood, they will form their own threads as they are screwed in.
Regards Mick
Ive made doweling jigs before in birch ply and drill bushings -they work really well and the ply is stable so stay accurate. Drill the ply using a drill press, accurate hole centres can be achieved using a stop and spacers cut on a saw and measured with digital calipers to ensure absolute accuracy.
Do you have a decent source of drill bushings? I was given a couple once before but have never found them at sensible money- I assume that they should be about a pound a piece or so? Maybe my coat is way out.
The axi set i think is for 9 of them so just over a pound each
other idea is the silverline pocket hole jig
it comes with 2 of each 6,8,10 and can be had for just over a fiver
Steve
or £3.62 in vat here http://www.birco.co.uk/index.php?route=product/product&product_id=3683
I looked at drill bushes myself before I bought a Joint Genie (which is excellent) the good ones were more like £6-7 if my memory is correct.
Four of these pocket hole jigs (eight bushes of each size) and you could make up three nice jigs bit of birch ply and a drill press, change out of £20, bargain.
Would be good for making up one off's, I might invest.
Proper drill bushes for engineering jigs are quite dear, £5 -£6 each from Boneham or Wixroyd. Ive not tried but Olite bushings are only about £1 from bearing boys for an 8mm x 20 long -I know bronze will wear but fine for a low volume jig.
Robin
the joint genie appealed but...and a big but....what if you wanted to fit a load of 35mm wide uprights to a rail
picture a cot with all the slats to stop little un escaping.......the genie seems to reference to an end stop and i cant see how it could work accurately on a long rail
maybe i not thinking straight
i got the wolfcraft but it self centres and also wont do the end of a 35mm....wasted my £20
the rockler one i looked at was a small block with a perspex window with a centre line that you clamp to workpiece
seems ideal for what i want..but imperial and usa only
so plan is to build similar with 2 bushes and just align to centre of my 35mm
hope this makes sense....i doubt it :oops:
Steve
You are correct the Genie references off an end stop but if you want to put dowels down a long edge you simply flip the end stop out of the way move the bar down and push a dowel through the jig into your last hole. Then continue drilling and if necessary move the jig down again.
It's a process shown on the videos of the jig that are on youtube. I appreciate you can't alter the spacings as they are goverened by the holes in the jig but you can accuately dowel an edge of any length.
