Pre-cat lacquers
PJ
20 May 2003
Northern Ireland
Are there any pre-cat lacquers which can be padded or brushed on or do the best results come from spraying. Also what nozzle size do the manufacturers recommend for pre-cat lacquers in conversion guns.
Any info would be great.
Philip
Information on spray guns isn't my strong point, but yes, pre-cats can be brushed (our Melamine Lacquer is a pre-catalysed lacquer), might need a bit of thinning depending on the size of the area to cover (use Cellulose Thinners) but I'm not sure about using a pad with them. Would probably work but you'd have to be quick!
Best results are of course from spraying if you can.
