Chris Howes
New member
Hi all
My friend has a wedding business and has asked me to help him design and make four large wooden letters (L, O, V, E) as per the attached. I've mocked up the L in Google Sketchup (also attached). You can see that it's like an L shaped box without a lid. Into the box I'm thinking of fitting another panel with the lights screwed on which can be easily removed for maintenance, with the cabling hidden behind the panel in a narrow gap.
The high level dimensions are:
130cm high
15cm deep
600cm wide
They will need to be durable yet movable. They should be able to cope with the odd bit of light rain. They need to be pleasant to look at but I'm no woodworking expert so they need to be easy to construct. I'm planning to send the designs to a company to cut the pieces out for me, so I'll just need to construct them and do any finishing/painting required.
The questions I can think of are: (sorry I can't be more specific, but it's hard to know exactly what to ask given my inexperience!):
1. What material should I use? Plywood? How thick? Should I make the back panel thicker than the side panels?
2. How should I join the pieces? Screws? Glue? Any particular joins?
3. What kind of finish should I use? Paint? Varnish? How do I waterproof them?
4. Any particular concerns around the electrical aspects? Is my idea to fit another panel inside the box a good one? Is there a better way?
Basically any advise would be greatly appreciated!
Thanks in advance
Chris
130cm high
15cm deep
600cm wide
Thanks in advance
Chris
