Plans, templets, formulae etc.
Phil Pascoe
29 Jan 2012
http://www.blocklayer.com/
Have a look at this - an absolutely amazing source of templets, formulae, general info. Stunning array of information, thanks to Yeungster79. There has to be something of use to everyone on this forum, no matter what their interests.
If you feel so inclined, please go to his post and thank him, not me.
post1120165.html#p1120165
A few that I've collected.
Anglesaw (inlay) - http://www.wood-veneers.com/downloads.htm
Blocklayer - http://www.blocklayer.com/
(Baluster, Circle, Cost, Deck, Dovetail, Fence, Framing, Gazebo, Pipe Notching, Pitch, Protractor, Pulley, Roof, Stair, Sundial, Tank, Text {large, printable} calculators/templates)
Bowlshape Software - http://software.billooms.com/bowlshape.html
Centering Ruler (10" or 26cm) - http://www.red-castle.com/software/fw/c ... gruler.htm
Cheatography (95 Cheat Sheets) - http://www.cheatography.com/
CNC Simulator - http://cncsimulator.info/
Convert (all) - http://joshmadison.com/software/convert-for-windows/
Corner (angles) - http://www.microsystools.com/products/corner/
Free Box Templates - http://boxtemplatesstore.com/
Lars (costs/materials) - http://www.wood-veneers.com/downloads.htm
MoxGen (Moxton antenna calc) - http://www.ac6la.com/index.html
My Collections - http://mycollections.codeplex.com/
Penchuck Software (rose engine patterns) - http://software.billooms.com/penchuck.html
Pipe Joints Templates (online) - http://harderwoods.com/pipetemplate.php
Template Maker (gift wrap shapes - online) - http://www.templatemaker.nl/
TrueTTY (send/receive radio messages) - not free
Winheli (RC helicopter) - http://www.birdcagesoft.com/winheli/index.html
Woodsearch - http://www.wood-veneers.com/downloads.htm
Electronics
(PCB = Printed Circuit Board)
Cads (draw/print circuits) - http://www.sigord.co.uk/Submits/Software.htm
CircSchema (circuit diagrams) - http://www.griffith.edu.au/professional ... circschema
Circuit Diagram - http://www.circuit-diagram.org
Circuit Maker Student Edition - http://circuitmaker.com/
Colcod (for resistors) - http://www.emdem.com/html/colcod.html
Diptrace (PCB design free = 300 pin limit) - http://diptrace.com/download-diptrace/
Eagle lite (PCB Schematics) - http://www.cadsoft.de/freeware.htm
Electronics Assistant (calc/resistor colour codes) - http://www.electronics2000.co.uk/download.php
Energy Spy (meter check) - http://www.mm-systeme.de/29.html
Esketch PRO V1.56 (circuits/capacitors/inductors/resistors - nffhp) - http://www.brothersoft.com/esketch-14295.html
Express PCB CAD - http://www.expresspcb.com/expresspcbhtm ... ftware.htm
Express SCH - http://www.expresspcb.com/expresspcbhtm ... ftware.htm
FreePCB - http://www.freepcb.com/
Jumo Temperature Controller (German) - http://www.mm-systeme.de/41.html
MUCS-PCB (Linux) - http://apt.cs.manchester.ac.uk/projects/tools/mucs-pcb/
OrCAd PCB Designer lite - http://www.cadence.com/products/orcad/p ... loads.aspx
Pcb Artist Layout software - http://www.4pcb.com/index.php?load=content&page_id=46
PulsePar (generator) - http://www.softbattery.net/pulsepar/index.htm
RCL-meter - http://www.rcl-meter.strobbe.eu/
Saturn PCB Design Toolkit - https://www.saturnpcb.com/pcb_toolkit.htm
ScopePar (Oscilloscope) - http://www.softbattery.net/scopepar/index.htm
Smith Charts (Speedometers,Thermometers & SWR Meters) - http://www.ac6la.com/index.html
Solve Electric - http://www.physicsbox.com/indexsolveelec2en.html
Speaker Workshop (design/test) - http://www.speakerworkshop.com/
SwitcherCad (electrical) - http://www.linear.com/designtools/software/
The Electric - http://www.staticfreesoft.com/electric.html
TLDetails (Transmission Line impedance) - http://www.ac6la.com/index.html
Zplots (Excel impedance) - http://www.ac6la.com/index.html
Electronic Labs freeware - http://www.tech-systems-labs.com/freesoftware.htm
Resistor Calculator - http://www.ab-tools.com/en/software/resistorcalculator/
Resistor Color Coder - http://www.schematica.com/resistor_colo ... istor.html
Resistor Identifier (hpnf) - http://download.cnet.com/Resistor-Ident ... 67927.html
Resistor Identifier (1)(online) - http://www.dannyg.com/examples/res2/resistor.htm
Resistor Identifier (2)(online)
- http://www.digikey.co.uk/en/resources/c ... ode-4-band
Engineering
1D Stock Cutter - http://astrokettle.com/pr1dsc.html
Ace Converter (DXF->Gcode) - http://www.dakeng.com/ace.htm
BMP To Din G-Code Converter - http://www.majosoft.com/engraving/html/ ... _tools.php
Bolt Calculator (scroll down page) - http://www.varmintal.com/aengr.htm
CAMBAM (40 sessions then 500 lines gcode) - http://www.cambam.info/
CNC Code Maker - http://www.cncsimple.com/features.php
CNCGraf (DOS)
- http://www.boenigk-electronics.com/web/ ... anguage=en
CNCnet DNC - http://www.wieland.us/cnc-erp/en/index. ... kel=678806
CNC Simulator (repeatable 60 day licence) - http://www.cncsimulator.com/
CNC Trace - http://cnclive.net/default.aspx
Copan (manage co-ordinates cnc?) - http://www.underhill.ca/
CStep - http://cstep.luberth.com/
Desk Engrave (CNC TTfont to Vector [G-Code/DXF]) - http://www.deskam.com/deskengrave.html
EmachineShop CAD - http://www.emachineshop.com/machine-sho ... ge100.html
Engineering Dictionary - http://www.engnetglobal.com/tips/
EngNet Tools - http://www.engnetglobal.com/tips/
(Currency Conversions ;Engineering Dictionary ;EngNet Clocks ;EngNet Tools ;Metric Conversion Chart ;Wire Guage Chart ;World Clock Chart)
Enhanced Machine Controller (EMC) - http://wiki.linuxcnc.org/uploads/flyer_v2.pdf
- http://linuxcnc.org/
Fast Formulas (Excel calculator) - http://www.engineering.com/tabid/74/Default.aspx
FractionCalc - http://www.theeastfamily.net/software.html
FreeMill - http://www.mecsoft.com/freemill.shtml
Gears (Paul Brussiéres - scroll down) - http://www.varmintal.com/alath.htm#Chip_Guard
Gear Train - http://www.theeastfamily.net/software.html
G-Simple (CAM) - http://www.gsimple.eu/
Impulse Counter (x12) - http://www.soft-collection.com/#SoftCol ... %20Counter
KMB Machinist Calculator (Keith Bunch) - http://kmbpros.com/KMBMachinistCalculator.asp
KMB Text Compare - http://kmbpros.com/KMBTextCompare.asp
KMB Trace - http://kmbpros.com/KMBTrace2007.asp
LinuxCNC - http://www.linuxcnc.org/
Macros - http://www.majosoft.com/engraving/html/ ... _tools.php
Mechanical Animations - http://www.mekanizmalar.com/
ME Consultant (Mech Eng tables - nffhp) - http://www.portablefreeware.com/?id=389
ME Weights (Michael Rainey - for metals) - http://closetolerancesoftware.com/MEWeights.html
MISC-Sim (Minimal Instruction Set CPU) - http://www.dakeng.com/misc.html
NC Link (DNC - reg req) - http://www.onecnc.net/general/new_downloads.htm
Rulers (G-Code) - http://www.majosoft.com/engraving/html/ ... _tools.php
Set Machine (pattern recognition) - http://www.optimasc.com/products/vis/#
Simple 2D CAD/CAM - http://simple2dcadcam.sourceforge.net/
Spring Calculator - http://www.goss-springs.com/spring_program.html
Spur Gear Calculator - http://www.dakeng.com/spurgear.html
Tap & Drill Calculator - http://www.cnczone.com/forums/showthread.php?t=2324
Target PCB Designer To G-Code Converter - http://www.majosoft.com/engraving/html/ ... _tools.php
ThreadPal - http://www.gewinde-normen.de/en/download.html
Valve Gear Simulators - http://www.smex.net.au/Reference/ValveGearSim02.php
VisualMath - http://www3.telus.net/public/ghlew/mysoftware.html
VisTool (vinyl cutting/engraving) - http://www.brothersoft.com/vistool-20018.html
VisualToolbox - http://www.brothersoft.com/visualtoolbox-17127.html
Wire Guage Chart - http://www.engnetglobal.com/tips
Metalworking Resources
- http://www.metalworking.com/
- http://w3.uwyo.edu/~metal/netstuff.html
list - http://www.craftsmanspace.com/
Engineering - Structural
Atlas (beam strength) - http://rekenwonder.com/atlas.htm
- http://www.thestructuralengineer.info/s ... 5-Atlas-20
BeamBoy Beam Analysis Tool (stress/deflection calculator) - http://www.softpedia.com/get/Science-CAD/BeamBoy.shtml
- http://www.smex.net.au/Reference/BeamBoy02.php
Frame3DD - http://frame3dd.sourceforge.net/
Membrane - http://www.ecf.utoronto.ca/~bentz/mhome.shtml
Structural Spreadsheets* (Hercules Ploumis) - http://yakpol.net/
(PGallery Creator ;Influence Lines ;Monty Hall Problem ;Surcharge Earth Pressure ;Travelling Salesman ;XLSudoku)
Modelling
Scale Calculator (model railway) - http://wesleysteiner.com/mr/mrcalc/mrcalc.html
I left out those on dressmaking & sewing & a few on philately. I'll add them here just in case.
Dressmaking/Sewing
Body Measurment Charts
- Butterick - http://www.sewingpatterns.com/butterick-measure.html
- McVall's (online) - https://mccallpattern.mccall.com/size-charts
- Simplicity - http://www.sewingpatterns.com/simplicity-charts2.html
Clothing Sizes - http://en.wikipedia.org/wiki/US_standard_clothing_size
- Vanity Sizing - http://en.wikipedia.org/wiki/Vanity_sizing
Cross Stitch Calculator (online) - http://crossstitch.about.com/od/learnho ... ulator.htm
Cstitch - http://cstitch.sourceforge.net/index.shtml
Cutter lite (dressmaker's basic patterns) - http://dmitriy-prog.ru/
Data 7 (free convertor/trials) - http://www.data7consultancy.com/free-em ... ftware.asp
DB-Bead - http://www.brunoldsoftware.ch/
DB-Weave - http://www.brunoldsoftware.ch/
EasyPEC (Brother PES files) - http://www.joachim-riedel.de/freeware/
EMBcopy (db) - http://www.joachim-riedel.de/freeware/
EmbroiderModder - http://embroidermodder.sourceforge.net/
Embroidery ABC - see Sierra
EMBview (embroidery files) - http://www.angelfire.com/realm3/ggs/
My Edotor - http://www.wingsxp.com/index.php/my_editor/
PESView (DST/PCS/PEC/PES) - http://www.joachim-riedel.de/freeware/
Ryijy Stitch Designer (pattern from image/photo) - http://code.google.com/p/ryijy/
Saw Handle Patterns - http://www.wenzloffandsons.com/faq/36-s ... terns.html
Scheme Maker (Cross-stitch/knitting patterns) - http://schememaker.sourceforge.net/
Sierra Stitch Era Universal - http://www.freesierrasoftware.com/
- http://www.embroideryabc.com/
SophieSew - http://sophiesew.com/SS2/index.php
Stitch - http://www.dsv.su.se/~henrikbe/stitch/
Stitch Color - http://www.brothersoft.com/stitch-color-65541.html
Thredworks - http://www.thredworks.com/index.php
TrueSizer - http://www.wilcom.com/PRODUCTS.aspx/TrueSizer.aspx
Waist To Hip Ratio Calculator - http://gigrallc.com/software/waist-to-h ... calculator
Free Design Files - http://www.joachim-riedel.de/gabi/
Philately/Stamps
AlbumEasy (Clive Levinson) - http://www.thestampweb.com/
FreeStampAlbum - http://www.freestampalbum.com/
Stamp Album Pages (USA) - http://www.stampalbums.com/free_us.asp
Stamp Collector - http://www.ducksoftware.com/stampcollector.html
Stamp Newsletters - http://www.silverdalen.se/stamps/downlo ... nloads.htm
Stamp Page Creator (Sami Kirjanen) - http://stamppagetor.sourceforge.net/
Stamp Word (Vasilis Konstantinidis) - http://www.oocities.org/stampword/index2.htm
Motoring
Drivers Log - http://touringmotorcyclists.com/tech_ti ... s_log.html
Well thanks again Robbo. I think my better half will be quite interested in some of your dress making & sewing links. I'll ask her in the morning.
AES
