wcndave
I've been planing some fairly cupped 34mm Maple, and was doing ok until one board whilst being edge jointed became tapered without ever removing material from the back end. I was pressing down lightly in the middle of the board. With a straight edge I can see the edge is slightly concave.
I then checked my tables (Scheppach HMS2600ci), and they were not co-planer.
I fettled the table, however 1) it is amazingly hard to level / adjust the tables, as there is no way to hold them whilst adjusting, and 2) I could not get both sides flat at the same time. If the fence side was flat (I tested by trying to get a 0.05 feeler gauge under the infeed and outfeed at both the end and the mouth), then the rear near side infeed was low. If I raised that, then the mouth edge of the fence side was low.
So I got them as close as I could, with 0.15 feeler gauge able to get under one corner of the straight edge of the infeed table.
I then reset the blades, however when the drag test was 4mm on the edges, there was no drag at all once I got only 2cm from the edge...
The blades have been recently sharpened and are straight when placed together on glass with white paper underneath.
I ran a few pieces over, and the leading edge of the board with the pressure gets thinner and thinner whilst the trailing edge doesn't and one trailing corner never gets processed.
I tried cup side down (unhappy smile), with a wobbly board, where with pressure near front the rear corner was 4mm off a level surface, and it still took a decent cut off that "raised" trailing edge...
Is it more likely to be the machine setup, or the technique?
I never seemed to have this problem until I "improved" the setup of the table - however I didn't have so much cupped stock before.
Any thoughts?
Any thoughts?
