Planer blade sharpening jig
MikeG.
24 Aug 2008
Essex/ Suffolk border
My back is stuffed at the moment, so I'm just fiddling about. Rather than laying concrete, which was the original plan, I decided to have a go at making a jig for sharpening my planer knives. Now, it's easy to think of a simple jig to hold the knives in place before running a diamond plate over the top of them, but my plates are fixed down into a board. I'm not buying new ones just for this job, so I came up with a way of holding the knives and taking them to the plates, in the way you would with any other edge. Electrons were disturbed in the making of this:
By design, the angle between the blades is just a tad under 90 degrees, which means that the leading edges only will be sharpened, rather than the whole of the bevel. In effect I am putting on a secondary bevel. I expect I'll sharpen the blades 3 or 4 times before sending them off for regrinding.
Previously, I had always left the knives in the planer too long, and had sent them off each time to a sharpening service. Now, I've no excuse and should be able to keep keen edges on my planer blades all the time.
It's a pair of rebates out of a square, then the edge planed off. The wood was squared up on the PT (because planing hurts my back). The little bracket/ clamp thingies were just cut out of scrap on the bandsaw.
If anyone copies this, don't make the mistake I did of making the rebates deeper than the thickness of your knives. They should ideally be just a gnat's under the knife thickness.
I've seen a lot of over the top, fiddly, planer knife jigs, but that's a really nice, simple, effective (and also quite aesthetically pleasing) solution. I'd make one... if it weren't for the fact my planer has three knives 😖
.......I'd make one... if it weren't for the fact my planer has three knives 😖
Then you need a total of 7 knives. Four out the planer at any time, so one will be unnecessarily sharpened each sharpening session. Just keep a careful track of which ones to use and when.
That looks pretty good Mike. I was looking at the various designs to do this myself just recently and I had decided on a similar approach. Once my current project is complete I'll knock one together. I also have the same diamond plates.
"It's a pair of rebates out of a square, then the edge planed off....The little bracket/ clamp thingies were just cut out of scrap on the bandsaw. "
Ahh! Penny droppeth! Still nice.
Thanks, Sam
Interesting idea. I wonder if there would be any problem imbalancing the knives, but I guess the difference would be tiny.
Nice solution. I've always used a piece of squared stock with a 45' enlarged saw kerf taking the plate to the stone, you rdesign is much better.
I have two sets of blades (three in each set). I use the first set, when they are dull I swap in the next set and when they are dull I sharpen all six blades in a similar jig (not as nice as the subject jig!) two at a time. This process means that all the blades are ground down at a similar rate with a consistent-ish secondary bevel.
I have a Dewalt 2 blade model. I place the blades into the jig, and with the jig clamped to the bench... I lap them with a diamond plate. Very easy and effective.
Yeah, but as I said, that means having a loose diamond plate. If your diamond plates are fixed into a board, that type doesn't work.
To remove heavy Knicks you can also use a single cut mill file to draw file. To do this you hold the file to a right angle to the knives and stroke the file from left to right without pushing the file forward while keeping an even downward pressure. After, you can use a fine stone or fine sandpaper stuck to a board, if you don't have a diamond plate. Planer blades generally are sharp using 600 grit.
Is anyone else not seeing these images? They've disappeared for me.
