PeteG
I've taken my blades in this morning to be sharpened. I'll be using a OneWay Gauge to set the blade height, so what is the ideal height to set
them above the out feed table?
Flush-ishMikeG.":3a728k0g said:Flush.
I've tried that method. Very fiddly so I just made them flush.Distinterior":33yizjut said:I thought i read or viewed somewhere...(a Steve Maskery video perhaps...?) that to set up the planer blades correctly, you placed a flat scrap of wood on the outfeed table overhanging the cutter head, then rotated the cutter head by hand and the scrap of flat wood should only move towards you by about 4 or 5mm...? or have I misunderstood?
Appreciated Inspector, that makes senseInspector":b98g2xj5 said:Use the supplied tool and then test cut. If it planes true then measure with the Oneway and write the number on the machine, the setting tool or keep it with the Oneway. If the supplied tool doesn't work then adjust until it does cut properly and record the amount.
I assume the outfield table doesn't adjust.
