First up - hello all, long time lurker, first time poster.
I bought a Wadkin 9" BFT planer a few months back and have spent many pleasurable hours taking it apart, replacing bearings, cleaning, adding a phase inverter so it runs off of household electrics, etc etc. It all went back together on the weekend and first shavings were made last night, gosh what a machine, doesn't even blink whilst taking heavy cuts in ash and oak, finished cut is smooth as a baby's proverbial. But...... you knew it was coming.... it seems to be adding twist to the board. On a 700mm long 75mm wide, 35mm thick board there is the tiniest bit of rock on the finished board, i'd estimate less than .25mm at the two high corners.
As far as I can tell I've got the thing set up ok. Ie blades well set, out feed table at correct height, tables flat and co-planner/parallel or whatever the term. However the planer is 1500mm long and my longest straight edge is a 1m dodgy Russian ruler than I have my doubt over the straightness of, or a 800mm spirit level. So my questions are:
1. Is it possible for the planer set up or my technique to be adding twist to a board? I read about how it can maintain twist via too much pressure or add bow via poor table alignment etc, but not found anything on twist!
2. What length of straight-edge would I sensibly need to give myself a fighting chance of getting the set-up bob-on and any recommendations for an item at a reasonable price.
Really I'm looking for someone to say. "Twist, from bad planer set up, absolutely! Now get back in t' shed and set it up right lad!" Then I'll show that to SHMBO and I'll be back in the shed tonight.
Fitz
Fitz
