Hi All,
I've been trying to build a gizmo for my lathe to hold the end of a 20mm diameter wooden shaft for end drilling, What better to use than a Pillow Block. I turned a trial shaft prior to slipping the block over the exposed end, only to discover that the axis of the shaft and the base of the block. were not parallel to each other.
My question is, how accurate should pillow blocks be? I have measured the slope away from parallel at 2 degrees. This gives rise to a 12 mm difference from one end of the shaft to the other. Photo attached.
