Dissolve
Hello,
I've been getting on fine with my jet pillar drill until now, but I've just started reaching my most precise work to date, and I've come across a really annoying gripe.
After I've set the depth stop nuts and locked them into place, if I lower the spindle to the depth stop, I get another 0.5/1mm of movement in it. Which itself, wouldn't be a problem, but this last bit of movement also wiggles the chuck to the side slightly!
In case I haven't explained it well:
- Depth stop set
- Handle lowered through work piece, depth stop reached
- With the smallest amount of pressure, the spindle is lowered another small increment (Possibly 1mm)
- This not only lowers the spindle lower than the depth stop but it also wiggles it to the side ever so slightly!
You can see the nuts on the spring feed adjustment move this last increment, but the depth stop threaded bar does not move, so I know this is nothing to do with a sloppy depth stop etc. The movement itself appears to come entirely from the spindle.
The spring feed adjustment casing does not move but the two nuts that lock together outside of this casing move.
Does anyone have an idea of how to solve this?
- Depth stop set
