Hi all, question on this as it is something i want to check before i start.
I have a outdoor dog shed (pic at the bottom) where the tortoise resides (and the kennel bit is fully insulated, boarded and heated!) and want to put some perspex over the windows to help keep the outside area slightly more sheltered from wind and rain, there will still be a 1.2x1.2 meter hole in the front so not looking for an airtight solution.
measuring the gap i can get panels from screwfix for about £40 all in (not looked elsewhere yet), this will be 2mm thick.
so the questions :
How strong is 2mm, could this be fitted without a batten in the middle or the existing metal panel (ie just windows), i can get 4mm which will be strong enough, but that is double the cost so maybe not worth the extra especially if being used with the metal that is there still. Considering things like strong gusts, wouldn't want it breaking with strong winds as its used outside the intended purpose.
Undecided if i will reuse the metal parts or not yet, its not really for security as the door to this area is unlocked anyhow but may
Fitting, i have used it before with a small countersink but that has cracked around the edge, so are there any methods or fittings to screw it securely without cracking. Probably only want 6, 1 on each corner and one in the middle of the long side.
Sun - this is on a South facing garden so in the summer will get direct sun pretty much all day, anything to consider?
so the questions :
