pen presentation
marcros
11 Feb 2011
Leeds
I need some packaging for something similar to a pen. It will not necessarily be used for storage after it has been bought but may be. It needs to protect the item during postage, and be reasonably readily available- numbers don't warrant custom packaging.
Does anybody use these or similar? http://www.turnerscabin.co.uk/index.php ... cts_id=382
I am not bothered whether it is polystyrene, plastic, or something with a cardboard slip. Does anybody have any suggestions.
On some pieces, I have seen people fill cracks and knots with aluminium filings. What do I need to search for to buy some?
Fiddler
13 Feb 2012
Morecambe
How about plastic water pipe from the DIY store? I received a violin bow from America packed in a plastic 2" pipe with no damage whatsoever.
marcros
11 Feb 2011
Leeds
it needs to look a bit more professional than that, and needs a case of some form, i think. Good idea for posting other things in though.
Spindle
7 Aug 2011
Aberdeenshire
Hi
Be aware that those pen cases have a clip moulded onto the base - the clip is only large enough to retain a very slimline pen.
Regards Mick
Neil Farrer
3 Jan 2012
Hitchin
Not too sure what you're after but these are the things I use, the slot takes anything from a PSI executive pen right up to a 16mm diameter chunky Majestic or Gentlemens/Chairmans/Sr Gents pen. It will take a slim line if they are turned with a wide top or bottom. The foam is coated with brush nylon.
Your other options in addition to the plastic box that you found which only take a straight turned slimline or fancy pen are acrylic tubes - part number ST111 from turners retreat - might be what you're after.
Hitch
28 Jan 2006
Somerset
I was thinking of the plastic slide together tubes or boxes like drills and cutters etc come in....
Capable of taking a good knock or two without breaking and I imagine they are fairly cheap.
They come in all kinds of sizes too, and obviously the length is adjustable.
marcros
11 Feb 2011
Leeds
These would be ideal, except that there is a bent wire piece on the end of the tool, so the cutout wouldnt fit. I wonder whether it could be modified slightly by cutting a channel with a dremel?
marcros
11 Feb 2011
Leeds
Thanks Hitch. I am going to have a look at these. Something that I hadnt considered, but may just do the trick.
marcros
11 Feb 2011
Leeds
nev":1mqhruo2 said:
No- there is a piece of wire sticking out of the end that rules out anythink like that. The overall size becomes 40mm wide or so.
I did find on turners retreat a version of the one that I linked to for larger pens.
Packaging in small quantities is a nightmare to get! There are many things out there that would do, but only sensible for 1000's at a time.
marcros
11 Feb 2011
Leeds
Thank you Nick. I emailed turner retreat, who have a couple of different ones like that, but they say that the clip is 7-8mm with no give in it.
I am leaning towards Nev's pricey option- it looks like it will show the product off nicely.
