Patchy finish on end grain.
digitalsmokehead
19 Sep 2010
Saddleworth
I've made an Oak money box which has 2 sides with striking end grain. My problem is getting the finish right. I tried a liberon oil finish but wasn't happy with the colour so I sanded it back down fully and tried a gloss varnish, slightly diluted with white spirit as instructed. The problem is light patchy areas which look awful.
I'm currently waiting for it to dry before I re-sand and try again.
I can only think its trapped dust after sanding. My cloth and vac didn't seem to remove it.
Any tips would be greatly appreciated.
could you avoid sanding it off- use a cabinet scraper or finely set plane instead?
marcros":2zondrmi said:
could you avoid sanding it off- use a cabiney scraper or finely set plane instead?
Thanks for the suggestion but I don't own a scraper and my planing skills ( both setting up and using ) aren't there yet. I've been using a belt sander to do most of the work and then worked through a few paper grits by hand to a nice smooth finish.
