Democratically?frank":28hmaeyf said:has anyone fitted parliament hinges is there a certain way of fitting them
I did a search for parliament hinges and found this page, which also lists projection hinges for use on doors opening 180°, may be the names are interchangeable? They are stronger which is the main reason JFC was recommending them.frank":115umi4j said:jfc what are elevation hinges i tried a search for them but no luck do they go under any other name .
