Quantcast
Parkside scroller
PeteO
New member
30 Nov 2020
Aberdare
Hi all. Relatively new to scrolling and just found this site. Earlier this year I bought a scroll saw from lidl for about £70. I've made a few pieces including some 3d stuff and quite pleased with results but attaching the blades can be a chore. Have anyone overcome this problem and is able to advise on ways to modify my saw.
Been to lidl today with my wife and found a belt and disc sander for £80 and wood lathe for £60. Couldn't leave them there. I'm happy buying cheap until I'm sure I want to continue with this hobby. Then I'll consider and upgrade if I can afford it.
Blister
10 Nov 2006
The age old saying " Buy cheap buy twice "
whatknot
29 Jul 2017
Cornwall UK
I disagree with the above, sure cheaper machines *might* put some off but the reason people buy cheap is generally because they can't afford to lash out £500+ on a machine they may never use for more than a few goes
Those with deeper pockets don't have the problem and may not understand why someone new might buy a cheaper machine
My advice would be to buy a better machine second hand than buy a new cheap model
I say cheap but you can get almost the same machine for under £200 new, £200 is a lot of money when you don't have much
But £200 or less would buy you a very good used machine
robgul
Barry Bucknell is my hero
13 Feb 2020
Stratford-upon-Avon
The OP question about blades hasn't been addressed . . . I don't think there is an alternative to the blade fitting/re-fitting on these basic saws.
And - it's a bit harsh to castigate the OP for buying a cheap machine - everyone has to start somewhere and for many people the basic Aldi/Lidl stuf does the job for the money. My own scroll-saw is a B&Q own-badged machine that originally cost about £90 I think - it was a Gumtree purchase for £15 and does what I want for occasional use! [Just made some 5mm plywood Christmas decoration shapes for our outdoor tree (y)]
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
If the op does a search of the scrolling forum section, he will find a plethora of threads about this very issue. They also have links to the suppliers of various adaptor kits that fit the lower spec machines in order to enable the to do quick change and take pinned and pinless blades. Before the software upgrade there was a sticky by AES that had a list of blade sources and also these adapters but I can't find it to link to
AES
18 Feb 2011
Switzerland, near Basel
Here you are (it's 2 posts above the OP's post):
whatknot
29 Jul 2017
Cornwall UK
You are right that I didn't address the question posed re blade clamps and ease of changing pinless blades
Assuming you have the most common blade fitment as fitted to most sub £200 saws
ie the "hanger" type which can be a pain to change for pinless blades (as per attached)
And wish to stick with the saw you have
You have three choices really
Use a conversion kit (Olson make one) but they are quite expensive and not that great to use
(from other users experiences, I haven't used one) about £25 or so
Use the Axminster type which replace the existing bent metal arrangement as fitted standard, which allows both types of blades to be used, not perfect but workable, easily fitted and costs around £10
Make your own if you have the kit, although I suspect you wouldn't be asking the question if you already have the capability
whatknot
29 Jul 2017
Cornwall UK
Attached shows the Axminster type blade clamps and how they look fitted
And the Olson type conversion kit
Also a variation on the sub £200 saw blade clamps which I assume you don't have (not interchangeable with the most common sort)
whatknot
29 Jul 2017
Cornwall UK
With respect, the post by AES covers the blades themselves but doesn't seem to cover the blade clamps the OP asked about?
Unless I missed it in the post
Ukulele joe
4 Dec 2020
Blackpool Lancs
Many thanks Whatnot, I did explain that it was the clamp and not the blades. Just as a point of interest I have only broken just one blade since I first started about 2 months ago!
whatknot
29 Jul 2017
Cornwall UK
That is very good going IMHO, I broke quite a few when I first started ;-)
(with a cheap saw ;-)
AES
18 Feb 2011
@whatknot : That's OK. I was simply "replying" to Droogs (post #9 above) where he said he couldn't find a link to "my" sticky about sourcing blades. No "my" sticky doesn't mention blade clamps.
PeteO
New member
30 Nov 2020
Aberdare
Many thanks for Advice. Appreciate advice more than the criticism for buying cheap. Will visit my local Axminster store.
