Ovolo Router Cutter Advice
sxlalan
21 Apr 2005
Skipton, Yorkshire
Another newbie question for them in the know...
I am looking at buying a 1/8" Radius Perform Ovolo cutter (P302011 Perform Ovolo Cutter - D=3/4" - X=3/8" - R=1/8" - S=1/4" at http://www.axminster.co.uk/product.asp?pf_id=22899&recno=4). Can the bearing on these be changed to make the cutter work as a rounding over cutter rather than an ovolo? If so, how do I work out which bearing to buy? If the cut radius is 1/8" and the bit diameter is 3/4" does this mean that I need a 1/2" diameter bearing (i.e. 3/4 - (2 x 1/8"))?
When cutting a rounding over edge using my router table, am I better to use a fence or just to freehand it with a lead pin? If a fence is better do I need the bearing at all?
Alan
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Alan
Give Wealden a call. Their technical department will have the information at their fingertips.
http://www.wealdentool.com/
Wealden Tool Company
Unit 31 Branbridges Industrial Estate, East Peckham, Kent. TN12 5HF
Sales phone 0800 328 4183
Technical & other enquiries 01622 872723
Fax 01622 872725
Email [email protected]
Office hours: 8.00am to 5.00pm Monday – Friday (closed Bank Holidays)
Neil
ike
24 May 2004
Yes.
3/8" bearings gives the quirk (ovolo).
Use the 1/2" bearing for roundover.
Safer/easier to use the fence for straight edges. I only use the lead pin when following a curve or template.
Keeping the bearing on minimises possibility of snipe.
cheers
Ike
DaveL
19 Oct 2002
Sudbury, Suffolk
Alan,
Of no real help to you but last year Axminster were selling these cutters on offer with both sizes of bearing at no extra cost :) I bought several. :D
The good news is the bearings are not very expensive anyway. 8) Have a look here.
Dewy
11 Jan 2004
Gloucester
sxlalan":2s70tl4s said:
Thanks guys!
Ike ... what's snipe?
thanks
Alan
Buy planed timber from a timber yard and you will find the end few inches is scalloped making it thinner.
This is known as snipe and is usually caused by the planer knives not being perfectly level with the outfield table although it could be caused by the rollers as well.
In other words its cutter dig in on the end of a cut.
