OSB with acrylic coating?
cedricb
14 Aug 2020
Derbyshire
...just wondering if somebody has used this type of product?
https://www.svtimber.co.uk/sheet-ma...te-protect-hoarding-grey-acrylic-site-protect
Looking to use it for a french cleat wall against a breeze block wall; 9mm OSB screwed against the garage wall and use these funky grey OSB for the cleat beams. By the way, do I need any air gap between the garage blocks and the first layer of OSB?
I was thinking to use it as well for a cross cut sled for my table saw; just for the base and maybe 2x4 for the fences...
any thoughts? 🤔
Wouldn't be my first choice but if you use it for cleats then make the strips reasonable wide, perhaps 80-100mm. I'd also be concerned that the mitred edge point could be weak. This is a job for 3x1 in my view.
@ £50 a sheet, you could get phenolic ply..... have a phone around your local suppliers. That said, i would go thicker for the cleats to be sure.
