Orbital sanding disks
digitalbot
9 Jan 2008
Mordor, just off the M1
I need to get some decent orbital sander disks. 125mm ones. So I was wondering which type/brand are the good ones that you guys use?
And what does the "C" weight, etc mean.
thanks.
I quite like the Hermes discs from Axminster, where the multi-hole design helps to reduce clogging over standard aluminium oxide discs and leaves less dust in the grain. For best results, you'd need to use your sander with dust extraction. They won't last as long as Abranet but, looking at Screwfix's site, they only appear to be available in 150mm diameter.
i was looking for some 2 but i wanted the high ones, 1000, 1500 and 2000 but only see them in 150mm size
...after 12 years! What are people recommending? ...just bought a DeWalt DWE6423; would need few different grits but without breaking the bank!
