condeesteso
It's arrived Dean!! Have pm'd you but not certain they are getting through just now.
There was a bit of teamwork to this one - Jim found it on ebay, I won it for a tenner (no other bidders), then due to a confusion in the listing, DeanN kindly offered to collect for me and ship it.
here it is:
A nice old wooden screw leg vice. Mostly appears to be softwood, but not sure about the actual screw under the muck - the nut is certainly softwood.
Things I note are the quite thin leg stock, about 1", so it would flex a little in use. The boss on the screw is a nice turning and quite a small profile which is good, as they can tend to stick out quite a way.
The bar is a solid turning with knob one end and a hole drilled the other for a peg - I quite like that and may copy it in future. The guide is pine and a bit bent, tenoned into the leg and fixed with a peg the outer side - not intended to be a very precise fit. The vice face is designed to be disposable and very easily replaced.
I can't tell how the thread was cut - no signs of lathe centres but that doesn't mean it wasn't turned. Thread form is very good and no break-out at the top of threads.
I'll have a think how to use this - could be a sliding leg vice maybe. Could be useful in the kitchen...
Very big thanks to Dean for going to so much trouble (and almost as much bubble-wrap).
here it is:
