Paddy Roxburgh
I've been making three Oak windows for a house boat this last week. two of them were simple enough but the third, replacing some badly masticed perspex,was a nightmare. the steel on the side had been partially overplated at some point in the boats history so the window frame had to sit on a totally uneven surface. this meant making the frame and then making stopped rebates (well,sort of rebates but not on the edges) where the overplated steel steel stuck out 4mm and the welds another 2-3mm. Yesterday I attacked the first piece of frame with a chisel and then a stanley router, doing some of the middle section with a non fenced rebate plane. The piece I needed to remove was nearly 1 metre long and 60mm wide, 4mm to 7mm deep. It was getting lateit was taking ages, there were three more pieces to do, I'm already way behind with this job so my price is looking more and more like minimum wage. I have a woodrat that I never use but couldn't figure out how to hold the frame under the router Eventually I did something I haven't done for a long time. In the corner of the dock is a cupboard full of tools I never really use, deep in there is a 1/4" makita router. Sod it I'll use it and get this thing done in a fraction of the time.
Well Luckily I didn't f@@k the work but boy it was a reminder of why I don't ever use these horrible things. dust every where , a couple of tilts that made a horrid uneven surface (which fortunately will not be seen), constant nagging fear at the knowledge that it was not really a safe operation (for me or the wood) and that high pitched scream of a fast running cheap electric motor.
Put it away and did the rest of the pieces by hand, didn't finish work until 9pm (I'd started at 7.30am) but it reminded me that an hour with a hand router and chisel is loads more bearable that 10 minutes with the makita.
I still use the planer thicknesser, bandsaw, table saw, track saw and pillar drill all the time, I have sanders but mostly they are for paint prep not woodwork, but the routers electric planes and biscuit jointers all live in the "don't use cupboard", I should just sell the things and the bl@@dy woodrat.
Paddy
Paddy
