Oak vase
sue denim
8 Apr 2011
South west France
I turned an oak vase this morning, nothing spectacular but I was chuffed as the oak was old, dry and as hard as hell's back door. Sounds bad but I actually got some sparks off the very end grain. Probably had some dirt in there. It dulled the tools very quickly.
I tried to drill into the end grain to insert an 1 1/2 pin chuck but found it hard going for the flat bit. I ended up turning out the hole for the chuck with gouges etc.
Question. For drilling 1 1/2 inch diameter into hard oak end grain which type of drill would be most suitable.
I am sure you all appreciate the cost of good quality drill , thus I don't want to spend a wedge on the wrong thing.
Thanks for the advice in advance.
regards
'Sue'
I would start with normal twist drill as big as you have.
I then use a set of saw-tooth forstener bits to open up enough to make finishing with a boring tool easier.
When I say use a set, I go up in steps as big as cutting resistance will allow.
Because the forstener bits have no central location to guide I turn a cone chamfer in the end so that the bits self centre.
An example of the method can be seen here although on a somewhat softer wood.
