Oak offcuts?
Chris152
26 Apr 2017
Cardiff
I'm looking to buy 3 x 10" (approx.) x 10" (approx.) x 48" lengths of oak, or whatever wood would be good for an outdoor sculpture (they'll remain whole and un-carved, just joined at right-angles toward one end). Buying from timber merchants looks pretty expensive. Couple of questions:
1. Is oak good for this in terms of durability? Or a resinous softwood like cedar? (And I'd like them to stay fairly straight - is air-dried best?)
2. Are those the sort of dimensions I might be able to get as offcuts from larger structural/ building work?
C
custard
20 Aug 2008
Hampshire
Chris, most timber yards won't have a clue how to deal with an order like this, and they may have quoted you a daft price to make you go away. You need to go to a yard who buys and processes the entire log. In my part of the country that would mean a yard like Tylers or English Woodlands Timber, or a smaller specialist like SC Scoffe who serves the agricultural fencing and timber framed building markets. I don't know their equivalents near you but they'll certainly exist.
Oak has a great reputation for exterior durability, but there are plenty of alternatives. One obvious option is Sweet Chestnut, which has all the durability of Oak but is about 30% cheaper.
With dimensions like this your only option is air dried or more likely wet, you'll very rarely find anything over about 100mm thick that's been kilned.
Argus
21 Oct 2002
Oak is traditionally used outside (Teak being almost unobtainable, nowadays). It lasts, but will eventually rot away. Otherwise, Chestnut.
I notice that some coastal groynes and other woodwork are being replaced with Greenheart which is rot-resistant enough for semi-immersion in the sea.
So........... on a non-ecological note, (it comes from South America) Greenheart may be the way to go, if you can get some off-cuts. It usually comes in huge baulks.
Happy hunting.
profchris
14 Jun 2015
Suffolk
As you're not carving them, why not find your local green oak building company? Mine (a neighbour) would probably plan you those as offcuts for sensible money.
The wood will move a bit, and maybe crack, but by the sound of it that might not be a problem for you.
Chris152
26 Apr 2017
Cardiff
Thanks all. I made the maquette for this over a year ago and have just waited to see if the right wood turns up, but nothing so far.
- I think that's the route, there are some small-scale yards not too far that might be able to cut what I need. I did find some off the shelf (https://www.uk-oak.co.uk/product/250_x_ ... _Oak_Beams) but transport's an issue (cost, I mean) as well as the cost of the wood.
I plan to join them with oak dowels/ pegs, so will be back at some point for advice on that!
Thanks again, Chris.
