Wurm
I am building a set of windows out of oak for an old stone cottage. I chose oak both because it was recommended to me for being durable in a maritime climate and also because it is traditional. It is just my second woodwork project, the first having been an airing cupboard of pine.
As I completed the first window frame its base section without warning split almost completely in two along its length, and subsequent inspection of the rest of the stock found a lot of pieces had cracks and splits of a kind that in a conker would be called a 'death crack'. Trimming the ends of a piece would often result in chasing a split until the piece was destroyed.
I am disabled so ordered air dried wood from a sawmill that I found online. It sat inside the cottage, which has no windows so plenty of moisture was blowing through, for several months before being cut. Seven further deliveries from two further sawmills have produced a lot of the same problem, which has often been evident as soon as I unpacked the delivery.
Some of the pieces that appeared OK have subsequently shown problems a number of months after being cut.
In a search of this site I found talk of sealing the end grain to slow the rate of drying, but many of the problems have been far from the end of the piece, so would it be a good idea to cut and plane the wood as soon as it arrives and then apply a sealer to every face? If so, what sealer would anybody recommend? I had been intending to oil the windows once complete.
Also, can anyone recommend a book which talks about this kind of thing? I have read two books on woodwork but none went into this kind of practical detail.
Here are some pictures:
