This is sort of a practice run for a blanket chest. So its a bit more "chucky" looking than I'd normally build. This was the project that caused the japanese stool to get delayed.
I had a look through the offcuts, and found a few nice bits of "pippy" oak. Seemed a waste not to show them off.
I started by planing a face and square edge on the P/T
Then thicknessing the boards
Once I was able to get a good look at the boards, I was able to decide on the dimensions for the box, and the layout of the individual pieces of timber
I had some 6mm plywood kicking around which would form that base. I used a 6mm cutter in the router to cut some slots. For speed, I decided to screw the box together with butt joints.
I soon switched up to the new raised bench with the better options for clamping :lol:
I chamfered each side with a low angle apron plane.
I decided 3 screws on each face would be sufficient. I'm marking up the positions.
Next stage is to work out the drilling sizes. I need a plug to cover the screw hole. 10mm is the next biggest size above the screw. (I'm using a dowel plate as I don't have any plug cutters!)
Then drilling.
I've decided to make this a "non-sanding" project. I want to use nothing but hand planes to complete the project. (maybe a scraper). I'm fed up with dust and sanding is boring.
[At this stage, I decided now is the time to give all my planes their first ever sharpening.
:shock: Thats right, I've been using them for at least 2 years now and never sharpened, honed, or anything. I used them straight out the box. You guys have seen most my projects so you know they get well used]. There. I've admitted it. Either I'm missing out on something or you guys are spending a lot more time sharpening than making projects.
Anyway, here it is smoothing the insides.
Next stage is drilling pilot holes down the end grain. No electric drill for me.
Dab of glue (PVA). Another thing where I've never used anything else.
Drilling the screws in.
To make the dowels, I'm using some walnut. Its 11mm thick, and I'm ripping it to 11mm.
Making that dowel....
The dowel was a bit loose. So I decided to remidy it. I cut it very close to the surface whilst the glue was still wet...
The pounded it with a hammer to splay the grain slightly. Result = nice tight plugs.
After the glue was dry..
Cleaning up the dowel with a low angle block plane..
Then smoothing the entire surface
And a bit later...
Chamfer those corners..
Lovely end grain shavings.... (none of these waterstones, this is straight back off the Tormek).
There we go - a box full of shavings - that lot could have been dust!
Using a #7 jointer to flush all the top surfaces. I've already done the bottom
Got a few bits for the lid
They aren't wide enough, so I'll add a strip of walnut. I need to plane it first.
Decided to biscuit joint the lid. No idea why. Easy referencing for glueup I guess.
Some glue
And clamps
Getting some danish oil on..
Looking good.
Will try and post some more piccys once I've uploaded them.
Adam
Then drilling.
And a bit later...
Some glue
And clamps
Looking good.
Adam
