I have a non working Nova DVR XP lathe and would like to put a 1624 - 44 headstock replacement on. Wanted to know if lathe beds are compatible, and XP tailstock will line up with a 1624 - 44 headstock OK. Any help appreciated.
Many thanks Pete, good call.To the best of my knowledge the bed extensions are the same for those series of lathes which would imply the parts would be interchangeable. I have a 30 year old Nova 3000 with the square beds and the new extensions will fit to it. Go through the Teknatool site to see what part number the extension beds are for each modle they sell. Bet it is the same number for each. Should be the same for the tailstocks of the models you are looking at.
Any reason you aren't seeing if the DVR can be fixed?
Thanks for the heads up, my workshop isn't exactly dry !!!Many thanks Pete, good call.
Unfortunately our DVR was sited in a dampish workshop, and hence suffered the dreaded condensation, which in turn blew the sensor chips on numerous occasions. Which was working out expensive. Speaking with Record Power at the time they said this was a common problem.
Fortunately I bought my DVR XP when Sorby were the UK distributors 16 years ago, this was all explained at the time & following their advice it‘s still performing admirable, shame Record didn’t do the same when they took over the distribution rights.Unfortunately our DVR was sited in a dampish workshop, and hence suffered the dreaded condensation, which in turn blew the sensor chips on numerous occasions. Which was working out expensive. Speaking with Record Power at the time they said this was a common problem.
Hi Pete,My gut feeling (a little too big but I can still see my toes) is that getting a new headstock will be expensive so finding a used 1624-44 lathe might be the way to go. You would have extra beds, tool rests, etc as a bonus. One of the things I do like about the Nova line is that they built on a good platform that is backward compatible rather than making changes for the sake of change. My 3000 is a 1624 that came with a flange mount for the motor rather than a face mounted one like some that came later had. That gives me the option of taking the single phase motor off, replacing it with a 3 phase motor and VFD, allowing me the variable speed option should I ever want it. My shop is fully insulated and heated so I don't have the moisture problem you have, besides the winter is too long and cold to work without it.Now if only we had more trees here on the prairie.
Get some extra belts for it if you can. They are not always easy to find. I ordered some from eBay in the US that were presumably for the lathe and they were the proper length but had 4 ribs and my pulleys have 5 ribs. They wouldn't replace them until I sent the incorrect ones back at my expense.Now I have a few spares so won't have to deal with them again. They don't break often but if you don't have a spare.....you know how it goes.
Good point, will speak to Record if they have any old stock.
The Item description is in fact the belt type/code i.e Poly Vee belt 584 mm long with 6 Ribs.
Register today and take advantage of membership benefits.
