Not the original plan
Waka
8 Mar 2004
Weymouth
Thought I'd continue with lathe practice and make another bowl, well that was the plan.
Surely I'm not the only one who's plans change midway through a project?
Things were going very well until I started to get a bit ambitious, it was at this point that I kept catching the tool resulting in bits of wood flying around the workshop. I had my suit of armour on so I was ok.
Its at this point where a well earned break is required and a re-think on what the final piece is going to be. The end result was a candle holder.
The wood is Pau Amarillo and the finish is sanding sealer and bees wax.
My next project is going to be a plate with starting dimensions if 11", it will probably end up the size of a side plate.
Well as they say practice makes perfect.
DaveL
19 Oct 2002
Sudbury, Suffolk
Waka,
Nicely recovered. :D
Bit of a drive by going on there. :tool:
You have spent too much time under the influence of Philly. :wink:
Alf
22 Oct 2003
Up the proverbial creek
Drive-by? I feel like someone's parked on my face... :roll: :lol:
Watch out, Waka, you might be getting the bug. :shock: Very nice result.
Cheers, Alf
CHJ
31 Dec 2004
Cotswolds UK
Waka":3dax8yys said:
...snip..
You do not have to be so honest Waka we won't know.
Looks like you have "seen the light" as far a Turning is concerned anyway. Nice one.
Word of caution if the next project is a Thin Plate: do not let to much time elapse between finishing both sides of plate. Try and work it all in one session if possible, if not you may come back to it next time to find that it is a different shape to how you left it as the tensions/moisture changes take effect. In fact you will probably see it moving whilst you are working on the second side especially if you impart any heat during sanding.
Just my experience to date, can't see it being much difference unless the wood is very dry.
Waka
8 Mar 2004
Weymouth
Don't know what you mean, if showing a candle holder is a drive by, what will you call it when I show my plate?
CHJ, Ihad heard that it shouldn't be left over night but rather make it in one go, looks like I'll have to get up really early.
