Norm Plans - Anyone used them
A
Anonymous
Guest
Just curious if anyone has bought/used any plans from NYW.
I was planning to build from the Mitre Bench plans, but thought I would ask you gents first.
beech1948
16 Aug 2004
Crowthorne, Berkshire
Biglouie,
Used the NYW plan for a pergola. Comments would be:-
1) Need some care in conversion from imperial to metric
2) Plans are pretty detailed with only a few items needing to be thought through.
3) Easy to modify to my needs
5) Cut list of little use as Uk metric sizes are sufficiently different to warrant a bit of recalculation
6) paper format is excellent...easy to pin up....only uses one side of paper...important if you want to pin to a board
7) Still need to make a full size drawing or draw out to size on ply/mdf to get repeatable accuracy
bye
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Hi B,
I've used the plans for Norm's Deluxe Router Table.
Clear, easy to modify, but no metric dimensions. Uses both sides of the paper, but each section is easy to scan to get a series of A4 sheets you can chuck about in the workshop without messing up the original.
I am very pleased with the result, and consider it good VFM.
Steve
wizer
3 Mar 2005
its a shame about the metric/imperial
I just cant get my head around inches!
A
Anonymous
Guest
I've used the plans for Norm's Deluxe Router Table too. Very pleased with them although there were one or two areas where they could have been slightly better
Neville Lawler
26 Oct 2004
Wigan
Hi
I used his plans to build the computer desk, no problems with them apart from not being metric. As I was fed up of converting the measurements, decided to purchase an imperial rule . Plans were supplied by Brimarc, excellent service.
Neville
Midnight
11 Oct 2003
Scotland
yupp......I've used em... and would again if the need arose.. well thought out, good clear cut list... best $10 I've spent...
Dewy
11 Jan 2004
Gloucester
mudman":32plgq34 said:
Just curious.
Why would you convert the dimensions to metric?
Surely you can just use an imperial measure?
Using imperial is OK providing the material is imperial as well.
Plywood is in metric sizes so some dimentions need changing to reflect this.
Mr Abrams has said for a few years that plywood seems to be about 1/32" smaller these days.
He would be more accurate if he said that it is now metric so 3/4" ply is now 18mm (about 40 thou smaller not 1/32")
3/4" = 19.05mm
I've worked in both imperial and metric since so called decimalisation in 1971 yet still prefer imperial, it has more divisors than metric.
I made the computer desk as well but not from plans.
I made mine from watching a video of the program and altering it to suit myself.
A
Anonymous
Guest
Martin Brown":mr6gu9u1 said:
If you bought and did not like we would happily refund you too. Did you get my PM from the shop thread?
Martin
Sorry Martin, did you send a PM to me? Didnt get it if so.
Jake
5 Apr 2004
London
I like to work in 1/373rds of a millimeter myself.
