Noob question but do cross cut sleds go out of square over time?
paul_allen
10 Dec 2021
Yorkshire
New to the forum, happy to be here.
I built a sled about 6 months ago and go it to 0.5mm accuracy over 2000mm using the 5 cut method. This morning I noticed it is out by 2mm over the same distance. Is this common?!?
Sled and fence are made of MDF and screwed together, rails are glued. I am very careful when moving and storing it, so I don't think it has been knocked or damaged. Only other thing could be the saw, but I check that regularly and I'm told the saw is pretty robust and doesn't shift around, it's the AT254LTS.
Any insight would be greatly appreciated!
To be fair, I wouldn't have made the runners out of MDF.....I have a small sled I made for segment cutting on my table saw and used pre sealed MDF for the sled and Oak for the runner.
This time of year, bare MDF is going to absorb moisture and likely to throw out the accuracy of your sled....It may be too late now, but I would think you needed to seal the top as well as the bottom of the sled.
Thanks for the info, I had no idea MDF absorbed moisture like that, seams obvious now. On my new sled then I probably shouldn't use MDF for the fence either, just use it for the base?
Make the runners out of an old plastic type chopping board - they never go out of true
