No35 vice
Jon bryant
19 Jul 2021
Norwich
Hi all
I'm new to the forum and was after a little help. I've just rescued a rusting No 35 record vice from the scrap .I have stripped it and put all back together but upon tightness the jaws just sprig back open which leads me to assume the half nut is worn.
I've been told these can be replaced but does anyone know where I can purchase one as looked everywhere .if not it's sadly going back on the scrap pile .
Thanks guys
Jon
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
Jon
Ive never seen or heard of one that worn.....are u sure it went back together OK.....?
my Record 36 was years old when I bought it and it's done a hell of a lot of work and it's still working OK....
they are worth a lot of money now so don't bin it.....there's always a way to fix these things....
Have u tried the nut on the thread...? is it all wobbly ...?
I can ask a friend for a parts supplier.....I'm sure he'll know......
Jon bryant
19 Jul 2021
Norwich
Jon
Hi
Probably should have mentioned it's a quick release vice. The thread on the shaft looks in good condition and has very little wear as constant along the whole length but the half nut has considerable where as very loose when placed with shaft. I have attached a couple of pics and you can see the heavy burs on the nut which leads me to believe it's jumping out upon tension .
dannyr
12 May 2019
Sheffield UK
Jon
Or
Hi
I have a QR - not this one - with similar wear which still works fine ----- is everything in correct orientation? spring pressure OK? - needs this to hold the half-nut in place - can be adjusted if spring not broken
Jon bryant
19 Jul 2021
Norwich
Yep just had another check and all seems to be in correct position and spring has sufficient tension. It all works as should apart from the jumping out under tightness.
--Tom--
16 Oct 2016
Cardiff
Bypass the qr and see if it holds then. That’ll help diagnose if it’s too worn.
If it does hold worth trying to add a couple of washers to take up any slack with the halfnut.
If either doesn’t carefully clean any burrs with delicate filing and then try again.
toolsntat
Yep, I collect tools and tat
8 Dec 2007
Leicestershire England
Could do with a better picture of half nut and screw thread but by the way it's jumping I reckon it's mullered.
Cheers Andy
Alpha-Dave
18 May 2015
Durham
Looking at your picture, it looks like many of the tips of the threads in the nut have rolled over, that means that the thread won’t be sitting as deeply in the nut as it should.
I would use some very fine files to remove the burs; this needle file set from Toolstation would be fine.
Jon bryant
19 Jul 2021
Norwich
Hi Dave.
Yes thought thats what problem is
The threaded shaft looks perfect but half nut as you say is badly worn. Think I may need a new half nut which I'm struggling to find but will try the file option first. 👍👍
