No hole through headstock
TFrench
6 Jul 2015
Leics
I made an ejector for my wadkin that threads onto the nose. Undoing it jacks the centre out of the socket.
Robbo3
28 Jan 2012
Oxfordshire
Record sell a thread protector which also acts as a centre ejector.
Lots of demonstrators hold the drive centre in the centre of their 4 jaw chucks for a speedy change over.
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
bobblezard
1 step forward, 2 back, 2 forward - rest - repeat
28 Jan 2013
Uk
The Axminster 50mm jaws have a disc with a MT 2 recess that fits tightly and flush with the jaws, this would allow you to use any MT2 accessories. But you'd have to remove the disc each time to knock out the drive spur etc ...
If that's a nova Chuck you have on the lathe? again you can buy a four prong drive spur to fit precisely like the one for the viper Pete linked to above.
paulm
IG paulm_outdoors
25 Sep 2005
North Hampshire
Orrrr flog the lathe and get one with a Morse Taper headstock. 🙄
It has a morse taper headstock :)
Albeit not drilled through, just means a thread protector nut/centre ejector is used on it rather than a knock out bar.
A chuck fitting is often easier though.
okeydokey
21 Nov 2014
West Sussex England
As Paulm says
It has a MT1 taper "hole" in the spindle buy a simple spur drive and just push it it, easy to fit BUT before doing that screw on the thread protector or you will have a devils job in removing the spur drive
Jacob
7 Jul 2010
Derbyshire
It's a fashion design weakness of many modern lathes where only one end of the spindle is usable. Half a lathe, in my opinion!
Mine has a normal spindle and the morse taper fittings just tap out with a long bar through from the outboard end. If you lose the bar 2no 6" nails with their heads off will do it
Nick S
27 Mar 2021
chard Somerset
One like this will fit the chuck you have.
Or you can make/buy one to fit the thread of your headstock spindle.
Thanks Pete have ordered a 4 prong drive from Charnwood the chuck is a record sc3 it comes with similar screw drive which is not that usefull.
thanks again
Nick
Nick S
27 Mar 2021
chard Somerset
Thanks every one have ordered a 4 prong drive center from Charnwood to fit the SC3 Chuck the record one looks bit naf so got the viper one and its cheaper be a lot easier than the screw drive chuck mounted supplied with the chuck.
Thanks for every ones help happy turning
Nick
Jonzjob
19 Mar 2007
Ex nr Carcassonne, France. Now Corston Malmesbury
My Record CL1 has a 1MT hole and I have never in the 20 plus years I have had it had any problems getting a drive center out. It only needs the thread protector as has been mentioned rearlier. There's no need to start belting a rod down a hole. Just hold the shaft flats with a spanner and unwind the thread protector, with a 3/16ths bar in the hole if it's tight. Done in seconds and no violence needed.
hlvd
21 Aug 2021
Anglesey
Our Record lathe at work has a knurled nut on the headstock side that’s used to eject prong drives from the morse taper. It goes on the thread that the chuck uses.
