Nick/chip in thicknesser blades - workarounds?
Bodgers
21 Dec 2014
North Yorks
I have at least one chip in my Metabo thicknesser blades. I noticed it towards the end of my bench build a few months ago, where I was getting some raised stripes in work pieces, but just worked around it with some smoothing plane finishing.
Without spending £40 on a new set of blades is it possible to adjust the blades in their holders to 'dial out' the stripes? Anyone tried it?
Pete Maddex
22 Apr 2005
Nottingham
You can off set the blades by the width of the nick to solve the problem.
I haven't tried it myself.
sunnybob
wysiwyg
11 Oct 2014
cyprus
Turn the wood around and run it through again at the same setting.
ColeyS1
2 Nov 2009
That's why I do. Just check first that the blade doesn't rub against anything!!!!
Sent from my SM-G960F using Tapatalk
Bodgers
21 Dec 2014
North Yorks
Yeah I tried that. It sort of works if you slightly it right. It gets a bit tedious after a while though
Sent from my Redmi Note 5 using Tapatalk
sunnybob
wysiwyg
11 Oct 2014
cyprus
what? more tedious than shifting the blades each time? :?:
Why not have a spare set of blades and swap them while the others are sharpened?
RobinBHM
17 Sep 2011
Wst Sussex
if they are only very small nicks can you hone the blades in situ with a diamond stone -I do that with both thicknesser and surface planer.
Bodgers
21 Dec 2014
North Yorks
It wouldn't be shifting the blades all the time. You would set them once and that would be it until they wore out.
The Metabo blades are expensive, just trying to extend the life before shelling out for my first replacement pair.
Bodgers
21 Dec 2014
North Yorks
Bodgers":ghvkv81g said:
Yeah I tried that. It sort of works if you set it right. It gets a bit tedious after a while though
sunnybob
wysiwyg
11 Oct 2014
cyprus
I'm missing something here, I dont understand. Educate me.
Its a rotary knIfe yes? with a nick in one of them?
So as far as I can see moving the blade across till the nick doesnt cut the wood implies that the blade is very wide and the wood is narrow?
Is that whats happening?
I couldnt do that on my thicknesser. I have had a nicked blade that left a bead along the plank.
Turning the wood and running the plank through again cut off the bead.
Bodgers
21 Dec 2014
North Yorks
Yes that's the suggestion. My Metabo might have a bit of wiggle room to move a blade to the side a bit.
Yes, like I say, you can do the replaning, it just gets tedious planing the same board twice. Particularly when you have 24 of the same part to do, which I have a the moment.
ColeyS1
2 Nov 2009
My planer has 3 blades. Moving one a smidgen gets rid of the lump.
Hornbeam
21 Mar 2017
Cheshire
The planer block will have 2, 3 or 4 knives all with a small nick in the same place. By moving a knife a few mm sideways the slight raised line left by a nick in one blade is reved by the undamaged part of the next one
Ian
sunnybob
wysiwyg
11 Oct 2014
cyprus
Hah! Now thats simple enough for me to understand =D> =D> =D> =D>
marcros
11 Feb 2011
Leeds
Is it disposable blades? On my Axminster they are locked/dowelled in place so you couldn't shift one along.
What about keeping a block plane handy and removing the strip with that? Depends a bit on how much you have to do.
