Next step-up Table Saw
Matthew S
14 Jun 2018
I am a hobbyist woodworking. I have been using the Evolution Rage 5S table saw for a few years. I have been very happy with it but am starting to reach some of its limitations as I take on more complex projects and want better accuracy.
What would you recommend as the next upgraded table saw to consider.
thanks
Jameshow
4 Oct 2020
Bradford
If not needing to be mobile then cast iron.
If mobile then a Bosch Makita / DeWalt will be a bit better accuracy mut you may kick yourself for not getting a proper cabinet saw.
Make sure it's an induction motor too. So much more pleasant.
Cheers James
againstthegrain
5 Jun 2009
South Wales
I have a Makita MLT100 table saw with which I have been very happy - 260mm blade and good accuracy... but I think if I were looking now and did not need such a large cut I might be tempted by a track saw instead of a table saw. I guess a lot depends on the space you have and your budget. I am also a hobby woodworker, not a professional cabinet-maker. So it is only a thought...
Fitzroy
All the gear...
12 Mar 2013
Aberdeen
Many of us on here have gone the secondhand route. Wadkin AGS 10, Startrite 175/275, Kity 618/619, etc. All great saws but may need some work to get set up running sweet and true.
DanZ56
29 Aug 2021
Ireland
Hello,
I have an Evolution Fury 5s that I bought recently as my first table saw. My first project is to build a new table and migrate the saw chassis into it, as I quickly realized that the existing table seemed to be very limiting. If your Evolution saw itself is in good order, maybe you could consider just building a new table for it.
Cheers,
Dan
