Newbie query, what components required
Michael Lewis
10 Jan 2020
Teddington
I was thinking maybe spacer fixed underneath each shelf... But the photo above looks like something else is used, wondering if there is some component I can buy that does this job.
DBT85
19 Dec 2015
Pershore, Worcester
I'm not sure any hardware is needed at all is it? 6 "shelves" with a hole in one end glued and if you like screwed to a dowel with a spacer between them while drying to keep them in place.
Stanleymonkey
15 Jun 2014
South West London
I think it might only be a dowel with short lengths of plastic pipe to keep them spaced out.
If you mean what tools. A pillar drill or drill in a drill stand would make drilling a lot easier.
Flat/spade bits are cheap for drilling the large holes - but can be a bit messy and splintery. Forstner bits are great for drilling very neat large holes.
Jameshow
4 Oct 2020
Bradford
You will need a pillar drill for one.
Secondly how about using empty spools for spaces with a washer above and below.
Or instead of the arrangement above how about a folding box with the spools in so that it can easily be closed and put away?
Cheers James
DBT85
19 Dec 2015
Pershore, Worcester
Not even sure a pillar drill is needed. A drill guide should suffice. Not like the hole has to be massive. A 8mm dowel would be more than enough for this job.
