New to turning - advice please
Togalosh
22 Sep 2011
Enclave Des Papes, France
Hello,
I have got access to a (good quality but not well equipped) lathe with the lend of some (not so good..ok poor) chisels & I'm really enjoying using it but I am not planning to get into turning to the same depths as you all are... I think...
I've read a few posts/threads on this topic & my main concern is that if I get a decent set of chisels (say Sorby) for £100 which is more than I can really afford & more expensive than the 2 sets of HSS ones from Axminster (but I'd hate to waste £80 on rubbish) how much more can I expect to pay for tools to keep them sharp? Can you point me in the right direction of what I'll need?
Also is there a good text book on the subject you can recommend please? I have Mike Darlow's Fundamentals of Wood Turning in my basket at Axminsters but I've bought some woeful books in the past & need to avoid doing the same again.
Thanks in advance for your help.
Togalosh
If you can borrow some tools, find out what you use most , and buy good ones one at a time: if you buy a set, you'll nearly always buy at least one tool that you very rarely (or never) use, which negates any saving.
+1 for keith rowleys book. it also contains a section on sharpening - whats required, why and how.
Its a question that gets asked a lot and if you use the search feature up in the top right of the page and search the turning forum for sharpening or grinders you'll have plenty reading :) (in short a 6 or 8 inch bench grinder with the correct type of wheel and a jig of some sort to rest the tool on)
I agree with phil.p buy your gouges one at a time. I find myself using either the skew or the bowl gouge 80% of the time, so the lesser used gouges can wait for the lotto win before theyre replaced :)
Thanks Nev & Phil,
..1 x Keith Rowley book on it's way & I'll be using the search option more in future (& resisting doing 5 things at once when online) .. I have modified a basic grinding wheel so buying another wheel shouldn't break the bank nor should 2 or 3 good chisels.
Thanks again for taking the time to respond.
Another downside of buying sets-- a row of identical handles won't do you any favours.
If you buy one at a time you can get different handles, or better get them unhandled and turn your own.
Another vote for Phil Irons book. I t would provide a more modern and attractive counterpoint to Rowley's book. I'm no doubt in a minority of one, but I find the latter a bit dated and dull. I don't much like his "laws of woodturning" approach, though I'm not disputing the solidity of the information it contains.
Ian
Ian
I have both books and they both have their merits but for the complete beginner its Rowleys for me.
I have actyally made a vey good semi circular cross section scew chisel my grinding down a half round file and making a handle in the lathe using a piece of copper pipe as a ferrel.. I also made a bowl scraper for getting under the rim by making a similar handle and griding down a large allen key to make a right angled scraper... old files are great for making scrapers with... I inherited a lot of good Sorby tools along with my lathe but my home made ones are the ones I use most !
