Quantcast
New lathe under £2k recommendations please
altennis
23 Aug 2011
sevenoaks, kent
Hi,
I am looking for a new lathe, going to be doing a variety of work on it, from spindles for furniture through to bowls and vases. I want electronic variable speed and the ability to turn the headstock. I have been looking at the Axminster AWVSWL1200, which seems like quite good value, does anyone have any experience with it? Is there anything out there which is a lot better and within my budget?
Alistair
Aled Dafis
29 Sep 2005
New Quay, West Wales
philb88":qi6uuyzi said:
Blister":qi6uuyzi said:
If you can get this lathe for around £800 £900 its a steal
http://www.ebay.co.uk/itm/300601603346? ... 1423.l2649
Not mine but I have owned Woodfast lathes before :wink:
Is belt-change though, not electronic variable! Already emailed them!!
That's only a minor problem, have a word with these guys
http://www.haydockconverters.co.uk/variablespeeddrives.htm
or you could do it much cheaper if you did the wiring yourself, it really isn't that difficult. You'd have an awesome machine, with change from £1500.
I have the short bed version of that lathe with electronic variable speed (bought from Blister) and it never lets me down!
Aled
Blister
10 Nov 2006
All this type of lathes have 5 belt positions and each one can be used with a variable speed control knob
I mostly had the belt on number 3 pulley , gives average torque and average speed
I sent him a message about the speeds and had this reply
" Hi Spindle speeds are 370 650 1200 2000 and 2700 rpm
Each one can be finely adjusted with a knob "
as a non wood turner his description of the variable speed control is somewhat vague " Knob " :mrgreen:
spasm
19 May 2010
Cardigan Wales
I also have the shortbed version of this lathe, to turn something on one of these machines is a hole knew experience, i payed £750.00 for it and think i got a good deal.
spasm
altennis
23 Aug 2011
sevenoaks, kent
It looks a pretty good lathe, but might be a bit overpriced by the guy at the moment, even if it is variable speed. You can get the Maxi 2 for under £2k if you look around with the bowl turning outrigger.
I am not sure if a fixed headstock is the right way to go for me as I was hoping to turn larger bowls in front of the lathe, rather than at the back, as i have limited space in the workshop.
Alistair
altennis
23 Aug 2011
sevenoaks, kent
I was pointed away from the round tubed Record lathes by someone else. Have you had any trouble with it?
The Maxi 1, also seems to have an attachment to turn in front as does the Apollo Professional, but none of them seem to be for sale at the moment.
A
Blister
10 Nov 2006
A
Personally I am not a fan of round tube bar lathes ,
but the bars are solid not hollow and are very heavy ,
Quite a few members use the Record CL1 CL2 CL3 CL4 range of lathes and recommend them
The CL4 is swivel head and full variable speed and £100 off at the moments :lol:
Again its all down to budget
This is a nice lathe also , either bench mount of on a stand
http://www.philirons.com/shop201108b/in ... ccessories
or one like mine :mrgreen:
Magma Black Line TITAN 400 , http://www.magma-tools.de/Director/idKe ... lack+Line/
Best lathe I have ever owned and cant see me ever changing 8)
Blister
10 Nov 2006
gregmcateer":hwkn9kmt said:
Nova XP for my money.
Greg
I binned my XP :twisted: , took it to the local recycling center :wink:
Maybe mine was a pup but when I wanted to use the 5 year guarantee as it went wrong and kept showing fault codes on the display
I was kindly told by Record that the 5 year guarantee does not cover the electrical side of things
They also offered to sell me a new headstock assembly for £1100 , yer right , Bin
Hope yours does not play up
