New Iron to big.
mtr1
10 Oct 2009
North Norfolk
So I've just got a new iron for my record 9 1/2 and it projects out of the mouth on its first setting by about a mil. So option 1, send it back, any replacement would potentially be the same? Option 2, grind off the offending projection, potentially losing the temper if I pineapple it up, then not being able to take it back. Option 3, find someone nearby with a tomek who would do it for me for beer tokens. Fill in option 4 please.....?
MMUK":hk9kadw2 said:
Could you not grind in another adjuster notch?
Just went into the workshop to check, and yes I can, in fact I've just done it with my Dremel. Plane now working without taking a mil off every stroke,thank you.
I tried the adjuster knob both ways as it has more travel if you turn the knob upside down, or the right way depending how you start. It was still projecting a mil out when the knob had hit the end of travel.
I have to assume you also had the cap iron set properly too, not too far from the cutting edge?
Ahem. It's a block plane - bevel up, no cap-iron (hammer) .
Cheers, Vann.
Cheers, Vann.
heh oops - I seem not know my 9 1/2 from my elbow - course he should ahve just said "my block plane" not get all fancy with fandangled numbers :)
rafezetter":3lmmkhtw said:
...course he should have just said "my block plane" not get all fancy with fandangled numbers :)
Quite right. I had to think hard too :wink:
Cheers, Vann.
