New fellow joins an asks for advice straight away
Bemused
25 May 2011
Hi, just logged in to here for the first time as an absolute beginner at wood turning without even a lathe.
I have had a hankering for some time to try my hand at some wood turning and are now at the point of considering the Charnwood W821 with W830 Chuck & W833 6 Pc Chisel Set to get me started for £362 from Poolewood.
Any advice guys
Many thanks
Tony
Well for starters before you part with any cash ask them if they have sorted the interference problems.
See this thread for starters
Nothing wrong with the choice of machine for size performance etc. but a lot depends upon what you find most addictive on the turning front. The size does tend to limit the maximum size of the projects that can be tackled.
There are several others of similar size and specifications from other brands.
Also be aware that it uses a brush motor - which are usually MUCH more noisy than induction motors. I've never heard this model in action but it might be worth you hearing it before you buy.
I asked a few questions at the Harrogate Show and got the impression there was no problem as far as Charnwood were concerned. All I know is I tried two brand new lathes and the problem was real. We had some laughs in our street, running an enormous cable from the top of the street to the bottom, just so we could rule out any problems local to our two houses, and we still had interference.
and dont forget you'll need to sharpen your tools almost straight away, so at the least- a bench grinder like the ones made by recordpower (under 50 quid) , or some fancy sharpening doobrey whatchamacallit from the likes of tormek (more than 50 quid!)
Thanks guys, I have now found the Axminster AWVSL lathe which seems to be a very simular machine for a lot less money.
The Axminster and Charnwood are the same machine, different colour.
I have done some more soul searching, interwebbing and have arrived at a new shopping list from Axmister
Axminster AWVSL900 Woodturning Lathe £233.95 Inc VAT
Axminster Clubman K10 100mm Woodturning Chuck (Body Only) £83.00 Inc VAT
Type C Dovetail Jaws £21.40 Inc VAT
This seems to give me a much better lathe for a total of £338.35
Just need to add some chisels
Tony
I can highly recommend the Axminster AWVSL900, I have had mine for a few months now and am very pleased with it, very quiet and steady.
Some of the axminster branded turning tools for around a tenner each are good too, I bought a roughing gouge and an oval skew as essential tools and they are pretty good quality.
I have also made a couple of scrapers from old heavy chisels (turned a nice long handle and 22mm copper pipe for ferrule) easy enough once you get the hang of it.
glad you changed your mind on the W821... Had my new one 5 mins and it blow all the house electrics and then blow up.... The replacement lasted 45 mins then blow up! Full refund given.... And old lathe fixed so kept usin that one which is a mini sip lathe
My friend purchased the Record Power DML36SH-CAM last year and I wish I'd gone for the same thing. £250 and it allows you extra bowl capacity at a later date should you require it with the swivelling headstock. I'm stuck with a 10" limit on mine. :(
Hey Tony and folks lol.
OK here's my £3.75 inc VAT worth lol. Buying a lathe as a beginner can be frustrating. There's so many places selling lathes, different manufacturers, different options to go with, etc.
The trick about buying a lathe is this:
Think about what you want to do on the lathe...
Do you want to turn bowls, hollow forms, spindle work, etc?
What distance between centres do you need or want?
Do you need variable speed or speed change via pulley shift?
Do you need something portable or floor standing?
There are various options to consider. Here are some do's and dont's when buying a lathe.
DO:
look into the specifications of the mathe and compare each lathe,
contact the supplier or manufacturer and discuss anything you need to know,
check out the warrenty plan for the lathe for your cover if something goes wrong,
Look at the accessories you are going to need,
consider expansion as you get further into turning. some of us turning folk either have one lathe or a few on the go, etc.
DON't:
Go and buy a cheap product. here's some tell tale signs. price between £150 and £200, cheap quality materials, imports, suspect brands (sorry to say NuTool as an example, B&Q own, challenge, etc),
Spend money on a lathe which is going to last 5 minutes and die a horrible death (examples including cheap motors catching fire, soft steels, flimsy leg stands, etc,
Rush into the first lathe you see, spend time instead researching the market and learn each technology and feature so you know what to expect,
Buy a small lathe and expect to produce big projects from it,
Buy a lathe that feels inadiquate, ensure you save up as much money as you can for a quality lathe which lasts.
I'm sure there's many more points to raise but because I'm a young blonde hamster with a faulty brain lol.
A lathe is a tool like anything else you use, they have weaknesses and strengths and can be temperamental at times. Don't give up just because something goes a bit on the cookoo side. Believe me, time, patience and confidence will get you everywhere in the turning world.
Here are some good makes to consider....
Record Power, Axminster (not the cheap models), Jet, Poolewood, Teknatool (Record power as a distrobutor) there are other professional makes as well.
If you want a lathe for a reasonable price but need something substantial, look into a used Harrison union graduate. most of them come as 3 phase from schools or businesses. they are very reliable, substantial and heavy duty. They can support bowls inboard upto 12in and 16 in outboard, etc. they can be converted to single phase or an inverter installed to utilise a 3 phase motor and use single phase 13A mains.
Throughout my time as a turner, both as a demonstrator / tutor and a workshop based turner for production and commission based works, I've used various makes, From Record Power who I have endorsed for a number of years, Axminster, Jet and teknatool. as well as union graduates and some unusual and specialist lathes including copiers and the likes of. For me, I can tell a high quality lathe from a copy in 15 minutes on a simple series of tests as well as a thurough tactile series of observations and in some cases take aparts which send shockwaves of horror to some people. Please don't perform a take apart of a lathe unless you are fully competent and the company showing the product off know you as a buyer.
Here are some recommended models I've worked with in the past.
Record: DML 305 and VS models (these are great for demonstration work as well as general turning. well made and reasonably priced), CL 1, 3 and 4 series are well known and decent machines capable of most turning jobs but beware... the headstock can undo itself and walk across the bed on occasions. The nova series of lathes are very well priced and offer a real degree of flexibility not just in use but also in expandability. you can make these lathes a custom solution to your needs and make them as long as you want to. The MAXI series of lathes made by woodfast in America are also very decent. The maxi 1 is a well built lathe and offers the user some nice advantages for high capacity turning. the Maxi 2 again the same but slightly bigger and a fixed head. however this model does not feature a reverse switch which is a problem if you are used to inboard turning and want to use that same position outboard.
Axminster: AWVSWL1200, AW1416VS. I refer to these particular models as the build quality and standards are very good for a woodturner setting out or even for a demonstrator.
JET: JWL-1220, JWL-1220VS, JWL-1642 and the higher end lathes for serious turners like the 3520B and 4224. The first two models listed I recommend for someone starting out who wants a reliable lathe for a very decent price. These are also widely used as demonstartion lathes at trade and turning shows. The third model is several steps up for some getting more serious into turning and needs larger capacities with a very reliable and solid built design. the higher range are high spec machines for production turning and large capacity turnings.
Lathes including the Wivamac series and Vicmarc I recommend for intermediate and pro turners due to price and high pedigree.
In my opinion and from an engineering background, the use of inverters and direct pullies as well as the DVR technology are the way to go. the use of a lathe where there is a speed lever is to be avoided. The reason for this is due to belt torsion. each speed is created by expansion and contraction of the opposing spindle plates therefore creating wear to the shoulders of the belts as well as heat build up and increased wear of the belt. these are not easy to replace in certain models.
Anyway Sorry this is a little long but I thought I'd add this from a blind turner's perspective.
lew
Thanks for all the consider response, in Particular the last post from lew, I have yet to push the buy button but are still leaning toward the AWVSL900.
Hi Guys, just updating.
Eventually I pressed the button on the Aminster and have been having fun for a little over two weeks now.
Pictures of some production, one of the better pieces has been stolen by a family member :)
Also done a few tool handles.
