New bandsaw guides from Axminster
Neil
It came to me in a flash when I thought the fixing bolt should be changed for a grub screw, at that point I thought maybe that grub screw ought to be against a flat on the bar, :roll:
Mike
Further refinements carried out today.
Mike
988/08/06
Since fitting these replacement guides I have not had any problems with them, they adjust well and seem to stay adjusted, quite pleased with them, was it worth the effort, yes I think so, if only for the fact I now have roller bearings and they face the right direction as bearings are supposed too.
Mike
One further refinement, slot the drop carrier to allow access to the rear thrust bearing bolt when using a wide blade.
Mike
Hi Mike
What did you do with the Yandles guide? I am thinking of making my own roller guides for the startrite, I have the tools and loads of bearings but having a guide to plagiarise would be a good start, even if I move the rear roller in the right plane :)
Andy
I have kept the Yandles guide as I am thinking of replacing the bearings on either side of the blade with the Yandles, as they have an eccentric bush which is easier to adjust than the Axminster screw adjustment system.
Mike
Thanks Mike, I may bother you for some photos/dimensions if I ever get around to it, for now I shall continue to swear at the blocks until they spur me into action.
Andy
Andy
Ask away, I also have all the original rubbing block guides and support brackets including a spare rack if you need dims or photo's, but they are in my workshop in France, going down shortly to close the place up for winter so I can take some photo's if you wish.
Yandles guide is in the UK so can give you any information you may need immediately.
Mike
