A
Anonymous
Guest
Hi all,
I started about a week ago making a coffee table with 2 drawers out of black walnut, well so far I have made the 4 legs, & the stretchers, I was going to do the stretchers & top out of solid but at these prices I came up with a easy way of making a veneer, I glued on a 1" thick planed board to some 19mm Ply, I then ran it through the bandsaw & was left with a nice 2mm piece glued on, I then thicknessed this to make it smooth, the stretchers & top are done with this method, the top is waiting on a solid breadboard edge, oh & the legs are solid of course
(this method is probably not anything new, just new to ME! hehe)
Im a little stuck now though as im lacking ideas, I came up with the idea of a very small bead on the stretchers which was a pain in the bum to make as its so fiddly, but the end result was worth it (I hope).
The problem areas are the legs, I thought of putting a double bead at the bottom of the stretchers for more detail (& to hide the ply edge), then I thought that this same bead could continue around the leg, mitred at the edge, but its below this detail that I cant think of what to do, so I wondered if you guys had any neat ideas?
Here are some pics to help you have some idea of what im building, the top is only placed roughly on top so you can get a better impression of the final piece.
This is an overall shot of the table, this is the back by the way, the front has 2 drawers.
Here is the front of the table:
Now about that beading, here are some pics:
Dont worry, that gap between the stretcher & leg is because I havent glued anything up yet :shock:
Any ideas would be appreciated, ive made up a matching leg in softwood so I can try out some ideas before carving up the expensive walnut.
Oh & the top is going to have a dentil inlay of 12mm, ive yet to order that from the net, but this is the design I had in mind:
This was from Anita Marquetry:
http://www.marquetry.co.uk/main/hub/hub.shtml
They only do it in 6mm, but I found this place that does a 12mm:
http://www.originalmarquetry.co.uk/default.asp
If you know of anymore sites please let me know, im not ordering just yet so....
Ok then, any ideas/feedback will be more than welcome,
Nick :wink:
Nick :wink:
