engineer one":9y27z30j said:
the blower makes short work of getting rid of dust which gets stuck in places you did not even know you had. :lol:
Just don't be tempted to use it on any electrical/electronic equipment
I'm a beginner at this compressor lark as well. This is my own Acme guide.
My initial requirements were for something to tack bits of smallish items together while the glue was going off. I didn't want to shell out much money. Everyone told me that 'the bigger the better'. However, I opted to buy the same compressor and nailer as the one slimjim is offering. I also bought the fine pin nailer from Axminster.
Observations...all work as it says on the tin although the brads/nails don't quite go where I expect them to...in other words I need to practice my alignment technique when using either nailer.
Folks talk about using compressors for other things. Definitely an air blower is worthwhile and cheap (£4 IIRC). Paint spraying? Well, I bought Steve M's HVLP and have used it once (anyone interested in buying it?). So I don't see me using the compressor for that but....big but...who knows in the future maybe? And herein lies the rub...
There are three factors that define the capability of a compressor (as far as I can make out). PSI, how big is the tank and what is the cfm. Some air tools require a large volume of compressed air...that's measured in cfm (and this figure isn't always quoted by manufacturers). Free Air Delivery (FAD) is another unit of measurement for the same thing (as far as I can make out) and is about 2/3 whatever the cfm figure is.
Manufacturers fib when it comes to accurately quoting cfm or FAD.
It is the type of air-tool that determines which of these three (or combination) is most important.
I use a big DeWalt Framing Nailer with my Bandit. It needs a lot of oomph (psi) and the Bandit quite happily supplies that. However, because the nailer is not on continuously, it does not need a large tank and so the compressor motor on the Bandit can keep the cylinder charged up ready for use.
I was going to use my compressor for a spot of sandblasting but this requires a high psi, very large tank and even larger cfm. In other words, a seriously large compressor. The Bandit simply does not have the puff. Research tells me I need to spend something like £1000+ for the sort of compressor to come anywhere close enough to supply the puff for something like a sandblaster...as it demands a continuous 15 cfm at least.
The professional sandblaster who did the beams in our cottage uses a CompAir compressor that supplies 270cfm (not a typo).
Compressor noise.....yes..it is. It makes you jump in the early days every time the motor kicks in. That's why many people stick them outside their workshops. You can buy quiet ones. Bambi is one make.
Oil - you need two types both readily available. One type goes in the compressor (unless it's an oil-less one). It's no big deal to keep it topped up.
The second type goes in the air-tool (especially if you're using something like a nailer). We're talking drops here. If your memory is like a sieve then some people use in-line oilers that are connected to the air-line and sort of drip feed oil into the tool as you use it. However, some folks advocate that these in-line oilers are not a good idea if you're going to use the same airline to apply paint! And, yet again, others advocate a quick spray of brake cleaner on the nails just before using them and not bother with any tool oil.
Hope that helps (or confuses!)
