Naerok WL12037
sean.brock
22 Apr 2007
Hi Everyone,
After a very long break from the forum due t family commitments etc I have just taken delivery of a Naerok WL12037 lathe. I understand it's quite an old lathe, but I'm hoping it will keep me entertained for quite some time.
I have a few questions and wondered if anyone could help me.
Is there anywhere i can get a copy of the manual. I can only find one link online and they're charging £35.
How do i clean the rust of the various moving parts? I assume good old 3 in 1 oil would do the trick but thought it best to check
The lathe has a faceplate on it, however I'd like to progress to a chuck at some point soon. This was the cheapest i could find, with what i think is the right thread http://tinyurl.com/ccdzklq would that be ok to start with (ie for a few years or so)
I did look on the members lathe list but could only find on Naerok lathe and it was a different model, so thought it best to ask everyone.
Thanks for taking the time to read this, and thanks in advance for any help offered.
Sean
i believe your thread size is 3/4 x 16 but there will be others along soon with more knowledge than i, and welcome..
I'll take a pic to upload later as it's different to those above. Main difference is that the sliding bar along the length of the lathe is a solid metal pole which slots into the motos side
Thanks for the replies
Sean
Hopefully the pic will upload
Robbo3":2tt3xvfo said:
I see what it is now. Similar to the Clarke CWL 12D
- http://www.machinemart.co.uk/shop/produ ... wood-lathe
Manual for Clarke CWL 12D & other Clarke lathes.
- http://www.clarkeservice.co.uk/product_ ... thes.shtml
Don't take the specifications as a given, they may vary between brands.
Robbo
Sean
I just had a quick look through the manual and was shocked by what I saw. I would never recommend using a block plane on a lathe :!: That is just one example. I would suggest you ignore the instructions given in the manual for how to turn.
Sean, that is decidedly what one would describe as a "beginner's lathe".
If you enjoy using it, I'm sure that you'll soon want to upgrade, (not the least because you'll get fed up of its speed changing palaver) even if only to something like this:
http://www.axminster.co.uk/axminster-ax ... rod780608/ or one of the other similar Chiwanese equivalents!
As far as a chuck is concerned, most of them are available in 3/4 x 16tpi. Lots of the "intermediate" lathes have 3/4 x 16 threads, But if you're looking at serious upgrades, you need a chuck with interchangeable inserts for different headstock threads!
Having said that of course, if you can afford things like Blister's Monster, the chuck becomes a throwaway item!
