Mystery Adaptor
PJM
11 Nov 2018
East Lothian
I have just been sorting my workshop and found my old Arcoy Dovetail machine which I bought 50 odd years ago as a youth, and in the same box was this adaptor made of Aluminium/Steel with an outer ring 4-1/2 inch diameter with an inner ring 3-1/4 diameter which sits inside and both have a recess on the inside of the centre. The inner diameter on the outer ring is 3 inches and the inner diameter on the inner ring is 2 inches.
I have no idea what it is an adaptor for but do not think it is for the Arcoy Dovetailer where I found it.
I know if I throw it away I will subsequently find out what it is for so do not want to do that. It looks like the sort of multiple size Router table adaptor that one normally uses but my router bench has a multi size plastic insert and on checking my old Black and Decker Router has no mention in the handbook or appropriate space to use it.
I am at a loss? Can anyone identify the adaptor ?
Peter Metcalf
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
wherever it's from.....give it a lick of oil and hang it on a nail somewhere......
I use this sort of thing to mark out corner radiai......I can never have enough......
Doug71
28 Aug 2016
Yorkshire
They look like filler rings from a spindle moulder, you put them in the table around the spindle to reduce the size of the opening if you are using a smaller block.
toolsntat
Yep, I collect tools and tat
8 Dec 2007
Leicestershire England
Sometimes they have numbers/letters on the back which might help identify the machine they are off of.
Cheers Andy
