Multiple question thread
tibi
27 Nov 2020
Slovakia
Hello,
I just want to save this forum's space, so I will ask multiple questions here that I am dealing with now. If you would like to answer any of my questions, feel free to refer to them by their number in your answers. Thank you very much.
1. What is the difference in usage between card scraper and cabinet scraper? Are they both used for cleaning difficult areas after a smoothing plane? If I have a card scraper, do I need to buy a cabinet scraper too? Is the difference just that a cabinet scraper is a card scraper with a holder? Do I need a dedicated burnisher or using a drill bit or a screwdriver is enough?
2. Why do people use 200+ grid sandpaper after scraping wood? Should not scraping leave a superior finish to sanding?
3. Are new Stanley spokeshaves any good? I have read that Paul Sellers recommends them. Do I need both with flat and round bottoms? I wanted to buy a Luban with flat bottom, but they do not have one with round bottom, so I would not have a match if I need both.
4. I have found out that If I want to buy a record 044 or stanley 050 that is complete with at least some cutters, the price with import and shipping fees almost matches the one of Veritas small plough plane. It is the same as with router planes. You cannot buy vintage on eBay for less than a brand new Veritas. I could theoretically buy body and blades separately, but if I add separate import and shipping costs, I am at the price of Veritas small plough plane. I have not found any other brand new plough plane, except for Luban/Quansheng 043, which costs just a little less than Veritas.
However, yesterday I have found this chinese plane on aliexpress, which costs around 45 USD. Do you think it may be usable?
5. Why fitting a tapered sliding dovetail is easier than a regular sliding dovetail? I can only imagine that I can mismatch the angle of the taper and then it would slide more easily.
When I have a vertical divider in a cabinet, can I use just a plain dado or sliding dovetail would be better? it would be 40 cm long.
Thank you for answering any of the questions.
Just4Fun
21 Sep 2017
Finland
2. I prefer a scraped surface to a sanded one.
3. I bought a new Stanley spokeshave 3 or 4 years ago, following advice on this forum. It did the job I wanted it to and I have used it on other projects since. I have no experience with any other spokeshave but I have no complaints about the Stanley.
5. The sides of a tapered sliding dovetail only contact the housing just before the joint is fully together, so you don't have too much friction to overcome during assembly. The sides of a regular sliding dovetail contact the housing over its full length and is harder to push together.
Cabinetman
5 Jan 2017
lincolnshire Wolds
4. I can’t say whether it will be any good or not unfortunately but I really like the look of that plane, looks more Japanese than anything else to my eye.
tibi
27 Nov 2020
Slovakia
Thank you Just4Fun,
I may give Stanley spokeshaves a try and I will get both flat and round bottom for half the price of a single Veritas spokeshave. I do know know how much I will use spokeshaves, so that is why I want to buy a functional, but not so great looking spokeshave instead of Boggs spokeshave.
5. Yes, you are right, mating surfaces will contact only when the tapered sliding dovetail is fully assembled, otherwise there is always a gap between the male and female part. I did not visualise it correctly before.
tibi
27 Nov 2020
Slovakia
It has some mixed reviews on amazon Rabbet Plane, Hand Wood Planer DIY Plough Plane Slot Grooving Wood Plane Shoulder Plane Adjustable Hand Plane for Carpenter Woodcarver with 5 Planer Blades - - Amazon.com
But I think it would be worth it just for the irons alone. I can build myself another plane and use the irons. According to reviews this plane is supposed to be used as pull plane.
TRITON
5 Oct 2014
Sunny Glasgow
A scraped surface gives you a hard surface,whereas a sanded one is a soft surface.
It all comes down to clarity.
There was talk a while back about sanding to very fine grits before polishing, and im not talking 480, but in the thousands. The point was to give that hard surface so the finish magnified the figuring clearer, as opposed to the lightly sanded to 480 which meant the 'picture' if you will remained slightly blurred*.
* Sorry, thats the best kind of description i can offer, but i think you know what i mean.
Orraloon
18 Oct 2016
Blue mountains Australia
1 A card scraper will give a very good surface that should not require sanding but it is hard on the thumbs if you have a lot to scrape. The cabinet scraper lets you do the work with less pain. Its good to have both.
3 Stanley shaves are OK if you fettle them. They come with the bed loaded with paint so scrape that off and if required lightly file the bed so the blade sits firmly. I have a stanley flat sole and a record round sole. Again good to have both.
4 I also like the look of the plow plane but can not say if it is any good. I have an old vintage english one that is nice to use but you seldom find one with a set of cutters at a realistic price now. At the asking price its worth a chance.
Regards
