Multico TM1 Tenoner Removing Heads
Status
Not open for further replies.
pollys13
19 Apr 2009
Swindon
The top and bottom heads which direction do I turn the head nuts to remove them?
Thanks.
Can't guarantee it's correct in your case but generally on machines to loosen things that hold blades or blocks on you turn them the same way as the blade or block spins. Theory is when machine runs it tightens nut, have seen nuts spin off when the electric brake kicks in!
The top head has a right hand thread and the bottom has a left hand.
Status
