There's three little tabs under the motor terminal cover
You will see six connections/three pairs of wires.
If its in wired in low voltage mode (delta triangle symbol 220volts) which is what you want it to be, you will see three "straps"
joining the 3 pairs of motor terminals.
If it is configured in high voltage mode, Star 380/420 you will only see two straps configured only in one line not paired
Two of these three straps is stacked on top of the other, and they need to be arranged the other orientation to pair up each winding.
Look up Bob/Robert Minchins/9fingers PDF on induction motors, here's a link, if it doesn't work look under his posts for the direct link which will work.
https://drive.google.com/file/d/0B_GZrX ... sp=sharing
http://www.thewoodhaven2.co.uk/viewtopi ... ors#p39194
Main things with VFD's are... not to put a plug in-between motor and VFD, and....
Program the parameters correctly (motor commands like speed) as you stand a very good chance of cooking your motor if you dont.
Main things for your safety is wait for the capacitors to drain from VFD before going near the input/output power terminals!
Tom
