Mouse sander VS orbital sander
Nedsss
2 Nov 2021
Cambridgeshire
I’m starting a business selling desks made of birch plywood, what electric sander would be best suited for this job? The desks will each be made of 4 separate pieces with a total surface area that needs sanding of 4 metre squared per desk.
I have already got a mouse sander, but wondering whether an orbital sander would be better?
Also, if you have any recommendations on how to leave a nice finish on birch plywood would be great, thank you.
Jones
5 Oct 2021
Gwynedd
You'll definitely need to sand before finishing and possibly to denib between coats so a random orbit sander will be essential really. Buy the best you can afford, festool or mirka if feeling rich. There's plenty on finishing birch ply if you search the forums, consensus seems to be that oil based finishes will yellow the ply so to maintain colour use water based acrylic or acid catalyzed resin.
MARK.B.
4 Jul 2012
East Yorkshire
Random orbital sander is the way to go, a mouse sander is really for those small jobs (hence the name mouse) that a larger sander cannot easily do because space is limited . You will be there for a week of Sunday's trying to use one on the project you have in mind :)
Kayen
22 Nov 2021
Grimsby
You will definitely need a 150mm random orbital sander. If you're going to succeed professionally, you will need to produce a high-quality finish very efficiently.
I have a Metabo SXE 450 Turbo Tec (circa £160), it's every bit as good as a Festool or Mirka IMO, perhaps a bit heavier, but that's not something that bothers me. You'll also need very good extraction to hook it up to, the bags they are supplied with are only good for occasional use.
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Both good to have, both made for very different tasks within the sanding process. The mouse will be good for edges and corners and the ROS for large areas. If the Festool or Mirka are too much, try looking at the Sealey "Mirkalikee" (See @petermillard 's channel) i got one for Christmas after he got around to reviewing it after a year of hard use. Great value for money.
petermillard
2 Oct 2009
West London
U
Both good to have, both made for very different tasks within the sanding process. The mouse will be good for edges and corners and the ROS for large areas. If the Festool or Mirka are too much, try looking at the Sealey "Mirkalikee" (See @petermillard 's channel) i got one for Christmas after he go around to reviewing it after a year of hard use. Great value for money.
It’s a great sander! 👍👍
Droogs
14 Mar 2013
Edinburgh
P.S.
Wear tinted safety specs, It can offend the eyes with its colour
mikej460
19 Jan 2019
Daventry
After some deliberation and a demo from a friend I opted for the green Mirka, the same as a Mirka Deros but built by Metabo. I've since read that Metabo make the Mirka? Anyway I'm delighted with it and it's around £100 less than the yellow one! I bought mine from FFX but they are out of stock so found it here
Metabo SXE150-5.0 BL 150mm Random Orbit Sander - Protrade
But if you are on a budget then Peter's Hvst sander or the Sealey equivalent looks a good bet (y)
