I only have 240V single phase supply into my workshop.
I currently run a 3HP 600mm bandsaw and 3HP 12 inch panel saw using VFD and have no problems
I am just looking at a Sedgewick single phase MB planer which has a 4 HP motor. Running current is no problem however start up is quoted at up to 87 Amps. They recommend a 40amp type C breaker which is no problem but I am concerned regarding the main incoming fuse which is only rated at 60 amps (neighbors property is a 100 amp fuse) . I should be able to get my fuse uprated but if I have more than a couple of KW on elsewhere in the property I could still tip over the threshold on startup Any conment welcomed
Ian
Ian
