I have an axminster ws10 something spindlemoulder, would you believe 2mth over the year old, and Its got a problem with the motor.
its tripping th earth leakage trips. Now a bit of investigation revealed a shorted brown (phase) wire to earth, due to the fact it went through a hole in the chassis which is minus a grommet....ok fixed that.
switched on ...pop....earth trip STILL jumping off the wall....Ok says me lets get a meter on this...now, not withstanding that the supplied wireing diagram looks NOTHING like the reality of whats actually IN THERE, I isolated the motor wires of which there are 5
brown
black
blue
grey
green/yellow
so ok green yellow is perforce earth
it would appear after poking them with a meter set to resistance that brown and black are one winding of the motor, showing a (dc) resistance of 1.5 ohms
which leaves grey and blue as the other winding...which reads open circuit to with the meter. No surprises there since there is a capacitor(from the circuit diagram a start/run cap) in series with this winding
HOWEVER....BLUE is dead short to green yellow (earth)... reads 0.4 ohm, which is the same as the residual error on my meter with the probes shorted.
so....does the pannel agree that the likeliest culprit is the start run capacitor having failed short to earth.
as an extra, Grey is NOT short to earth......
brown
black
blue
grey
green/yellow
